Gas Cap question
Newmarket, Ontario north of Toronto
1999 ST1100
When returning after riding on a hot day, prior to parking in the garage, you could twist off the fuel cap to remove the excess pressure, then tighten as normal and park. This may reduce the subsequent "hissing" and fume concern you have. Might not work, but suggest you give it a try on a hot day.
Moses Lake, WA
1991 ST1100 in Black
After putting the clamp on the line I mentioned earlier, I have not had any fume issues, and the pressure in the tank is way down after I fiddled with the cap adn moved the internal parts with a thin wire. It may have been stuck from lack of use, but it works ok now. As for carb cleaner, I thought it would be safe on the rubber...but if not, then I can always do a solvent dip.
Bulgaria
Can anyone tell me if this is normal operation of the gas cap?
When I open the gas cap of my ST1100 after a ride, or even when it has sat for a week, there is this hissing soung ( air goes into the gas tank). So the cap doesn't let outside air in when the engine is running and this creates vaccum. Is this normal? I think this can make the life of the gas pump hard. Sprayed the vent hole with silicone spray and blowed some air into it to make sure the valve isn't stuck. I've been thinking of drilling a small hole in the gas cap to resolve the problem, but I'm concerned of gas fumes. Any suggestions?
Smudgemo
Intermodal Man of Mystery
Berkeley, CA
'08 GS / '78 CB550
Mine doesn't seem to properly vent either. The red hose is clear, but typically pressure builds up in the tank past the point where I'd think it would vent. I'm hesitant to take apart the cap as outlined in one of the tutorial pages until I'm at least sure it's not functioning properly. I was thinking about soaking it in something. I've got a bucket of carb cleaner but will that wreck the internals? Got me.
Northumberland UK
VStrom 650
They all seem to do the same.
Just ride.
Upt'North.
kankakee
R1200rt
Leave it alone, pressure buildup is normal. You have a hot engine right in front of the gas tank.
kankakee
R1200rt
If it was a vacuum it would stop running, it's pressure and completely normal. Leave it alone.
Fort Worth, Texas
91 ST1100/06 ST1300
I rode mine home from the dealership...about 90 miles. Checked the bike over really well after a day or two riding, looking for issues as well as enjoying the bike. First time I removed the gas cap, I got that sucking/vacuum sound, but had experienced no running problems with it. I replaced the vent hose and gas cap because the cap vent appeared to be plugged. Same vacuum sound afterward, but didn't seem to be as pronounced. Chose to ignore it.
CYYJ
Michael
Toronto & Zürich
None any more.
2636
When troubleshooting fuel tank venting issues, keep in mind that the cap itself is not the only possible cause of the problem.
The vent hose leading from the cap down towards the bottom of the bike can become plugged at the bottom from road debris (usually mud), or kinked somewhere along its winding path. So, take a moment to disconnect the vent hose from the cap and blow a little air down it - or pour a little soapy water down it - to make sure that the vent hose is not obstructed.
Michael
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
BTW, ST1100 trivia: that little hose has a T connector* inserted inline towards the bottom. It’s not connected to anything. The WoTL over the years is that it serves as a backup vent. This little “issue” comes up every few years when a STrider finds it while venturing into the bowels of their beaST for the firST time. IINM, it can be found by looking closely at the online fiche (forgot which one).
edit: item 23*: LINK
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
JuST to be clear, the cap vents both ways (poSTs #12 and #14). While underway, the fuel level drops creating a vacuum that at a certain point the cap relieves. Take the fuel filler cap off immediately after stopping and you’ll hear the rush of air entering the tank. If you juST leave the ST sit without opening the cap, engine heat will eventually pressurize the tank and the cap will release it, often generating a moaning/groaning/humming sound, and a forum query.
jrp
Colorado
ST1100AW
8991
I noticed the same thing a couple of years ago. I disassembled the cap and found that it was clean. It appears it takes quite a bit of pressure to overcome the valve.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Hmmm.... there should be a spec for pressure release, and for vacuum. I’m sure there’s a standard for the cap manufacturer to meet. Now to devise a test using my Mityvac... :think1:
STRider
Oregon
2012 ST1300A
50
Yes, my 1100 has been moaning and groaning for years. I get concerned if it doesn't!
Maine
I'm just dropping a note of thanks into this years-long thread - and sparing those who know another forum query: I have a new-to-me ST1100 ('92, 40 amp alternator swap) with the "hissing" sound from the cap. It's good to know that it's basically normal. I'm not getting any (or much!) vacuum in the tank, as there's no fuel starvation issue. Today, while working in the yard, I heard it even though the bike hadn't been started in a day. I guess that sitting in the sun on a 90+ degree day led led to expansion of the fuel - and a need to blow off a bit of pressure.
Slydynbye
Will ride for Pie
Fremont, California
2000 ABSII
7331
Don't let that Beautiful 92 sit in the Sun too much, it fades the Paint.
