I moved this fuseblock from one ST1100 where it was functional, to the other. Hooked up the same way or so I thought.
It is not getting power and I have no idea what I'm looking at. For example, due to some weird mental block, I don't get what a relay does even though it's been explained to me a hundred times,
The large red wire which is connected to the blue one from the relay goes right to the battery positive. It is fused.
The yellow goes from the relay to that little mounting screw.
The white one goes from the relay to a frame bolt on the left.
The smaller cut red ones were already like that, one being connected to the black to the relay.
Some help from you electrically knowledgeable here would be much appreciated.
Thanks
Thanks
