Working thru the manual, checking everything twice on my 'new' 1991 1100........There is NO mention of lubrication of the universal joint. Is something missing, or is this a maintenance-free component?
Correct - If you are doing a thorough strip down of the bike though, including pulling the swing arm, then lube the splines on the output shaft and the driveshaft splines too.or is this a maintenance-free component
There is no regular maintenance interval on that prop-shaft, but there some essential check and lubrication points during a re-assembly after having removed the swing-arm...There is NO mention of lubrication of the universal joint. Is something missing, or is this a maintenance-free component?
+1 .Correct - If you are doing a thorough strip down of the bike though, including pulling the swing arm, then lube the splines on the output shaft and the driveshaft splines too.
The u-joint is a sealed unit. No way to lube it.
It doesn't come off. There's a filler cap (don't over torque!), and a drain plug... not chrome.OK....been staring at it and poking it all afternoon. It's apparent this meditation thing isn't going to enlighten me. How does the chrome breather cap come off of the final drive unit? Press fit? Screws off?
If you're talking about the chrome breather plug on top of the final drive unit, it does come off. Honda might have press fit into place.OK....been staring at it and poking it all afternoon. It's apparent this meditation thing isn't going to enlighten me. How does the chrome breather cap come off of the final drive unit? Press fit? Screws off?
That's the part. My Honda manual simply says 'clean the breather hole and reinstall'. No mention of a removal method. Looks like the Honda writers were taking lessons from the Haynes manual folks.If you're talking about the chrome breather plug on top of the final drive unit, it does come off. Honda might have press fit into place.
41306-MB0-010 CAP, BREATHER
When I got my current bike, instead of the usual chrome plug there, it was missing and PO put a plastic rubber plug on the vent hole
I bought the plug and asked my mech to use a mallet to knock it back into place. The OEM chrome plug has a stem and will slide into the hole tight but strength is needed to push that in
