Rear brake and turn light problem
Dave Weeks
DaveW
Niagara
98 ST1100
Hello, I've read as many posts as I can to no avail. My rear tail light dims when either foot or hand brake is applied and fails to illuminate brake light, and rear turn signals dim while attempting to flash, causing opposite turn signal to appear to blink weakly, along with dimming of the tailight. I have cleaned all connections and checked everywhere I could for connections/fuses etc. This seems to be after I bled brakes, clutch, and unbolted right side foot plate to access muffler joint, but did not disconnect any brake components. Any further ideas? Front signal lights are working fine.
The Cheese
Check all the grounds. In particular the one that connects to the frame on the clutch lever side side of the rear cowl. 10mm hex head bolt, covered by the side cover, forward most one, two wires. Butt its just a shot in the dark. Electronics do weird things when they don't have proper grounds. With you doing work in that area I bet a ground was left off.
agree with the cheese, when multiple unrelated systems start acting funny, with symptoms that suggest low voltage supply, its usually going to be caused by a bad ground connection somewhere. The logic behind this is fairly simple, the corrosion or whatever gets introduced into the ground path creates a significant voltage drop on the ground side of the electrical devices. Since the current path from battery to ground has 12v potential over the entire path, any drop on the ground side reduces the available voltage supply to the device.
I'd start by taking a static resistance measurement from the ground side of the bulbs in question to the negative battery terminal (which should be ground). That should be pretty much a short circuit of a few tenths of an ohm. If its more than that, then take a similar measurement from the negative battery terminal to a clean, unpainted part of the frame, that should also be a few tenths of an ohm. This should tell you in which part of the ground path the problem lies.
If both of those measurements check out OK, then test the supply voltage to the lights with a voltmeter. If the supply to the bulb is less than about 12v, you'll have to trace out the drop on the supply side. If the supply side voltage checks out OK, measure the voltage drop from the ground side bulb terminal to the negative battery terminal. If that's more than a few tenths of a volt then you have a ground side problem that you'll need to trace out (but the previous resistance measurements should have detected that kind of problem). Between these tests you should be able to isolate the location of the problem, then you just need to find the cause in the wiring.
Dave Weeks
Dave Weeks
DaveW
Niagara
98 ST1100
Thank you I'll try that. I thought I was smart cleaning up the bare metal for the one ground wire on the frame just above the lift handle on left side, is that where you are saying there are two wires?
Avtrician
The symptoms suggest looking at the earth/return wire in the tail light indicator wiring. That is the only common link to those lights.
