I posted this not long ago and got a couple of suggestions (see below). The noise has remained and I've refined my description here. I also took the bike to my local dealer (I think they are pretty good, have had good reports from friends who use them, and they have a pretty good reputation in general). I had them do some minor maintenance items and diagnose this problem. And this is what they said.
The noise: After downshifting from 5th to 1st then to neutral on approaching a light (usually 5th, 4th, 3rd, 2nd, 1st, neut all the way down w/ clutch pulled in, Not 5 to 4th, engage clutch, slow, shift down to 3rd and engage clutch, etc.) I wait for the light to change. Upon clutching, shifting to 1st, and engaging the clutch, there is a 'clank' that I can not only hear but feel - usually when the clutch lever is almost all the way released. This happens after about 5 miles of stop and go traffic or when the bike is thoroughly warmed up after a run on the highway. It happens almost every time after an extended ride on the highway, and I've only recently noticed it also occasionally between 4th and 5th gears. The sound is like the center stand slapping the underside of the engine.
Suggestions last time I posted this were a bad u-joint, the smc, or a loose shifter linkage.
My bike is a 2010, 27,000 miles on the clock.
I took the bike to my dealer for some minor work and diagnosis of the problem. He said they think it is a clutch spring that is getting weaker and allowing the assembly to make noise as it is engaged.
I do not think it is any of the originally suggested items because the symptom does not fit what I know about u-joints, the smc, and the shifter linkage is not obviously loose. I read the shop manual and the clutch looks to me to be similar to the old Triumph and Guzzi clutches that I have had apart (though it is not very easy to reach). I don't see any one spring that might make the noise, but if two adjacent springs were weaker, then the clutch could hang up and perhaps clunk when the sticking is released. I suppose it could also be a transmission problem, but the dealer's mechanic leans toward the clutch.
Any comments, ideas, or diagnoses that I can run by the dealer? I plan to take the shop manual with me when I pick up the bike Monday and ask him loads of questions. They suggested doing the work at the end of the season since it was not serious and poses no immediate danger to damage to the bike now. I have to decide if I want to undertake this job or remodel a bathroom this winter and work my day job. Not sure I can handle all these tasks along with the usual end of the year routine maintenance and accessorizing of the bike and maintaining our car and truck.
Oh yeah, he said it would take about 4 hours (shop hours) plus parts. My guesstimate is $300 labor + 100 parts + tax etc or about 500. I could always strip the fairing off and do that myself to save some money. Were I to do it, I know it would take double that in straight labor plus down time ordering parts, soliciting advice here, etc..... Been there done that.
