Hi All,
I left the 2005 ST out in the elements the other day, and the rain came down while at work on that day. When I went to fill it up with gas today after coming home from work, there was fuel/water hanging around just inside the tank opening ring. I knew something wasn't right. At this point, I'm not sure water is getting through.
After drying out the inside upper area just inside the fuel fill cap with a paper towel just now, I noticed the left side drain is completely plugged with residue.
With all that said, and I'm sure some of you have dealt with tank top issues, should I just go ahead with replacing gaskets etc?
Anyways...what do you all to clean up this area?
