Well, whatever my issue was, I cured it. Thanks for the help!
Sent from my SM-G900V using Tapatalk
From reading a lot of posts for many years you risk melting your reflector with 100w bulbs... And if you think the LEDs are expensive wait until you check the price of the headlight assembly! DOH!!!What do I have to worry about IF I just go that route?
Good!driving lights NOT the headlight assembly
Thanks for the help. Didn't think I l8ked the mirror idea, but after conversation with NerSteve, that may be the way I go. I can fab brackets cheap, just need budget friendly leds to make it happen.Good!
Sorry for the misunderstanding.
Can't help you on better visibility as I know of only mirror mounts that hold up to long term use.
And less prone of having the filaments rattled apart...The mirror mount is solid
Unless you run into fog, then you'd want them as close to the ground as possible...the higher up the aux lights are mounted, the better.
So you never found the problem? They are good lights.I have some driving lights now,
Not sure what the issue is, thinking I may just replace them and start from scratch.
