Throttle body removal tool
I came up with a pretty easy way to remove the throttle body boots without prying, cutting, and damaging anything. All you need is an air compressor, air Chuck tool, and an extension for the nozzle. Some lb blaster on the edge of the boots then slip the tip of the air Chuck under the edge and blast it with air! They pop off as easy as removing your hand grips with the air method. Hope this helps someone.....oh yeah, it won't work on bikes with 300k miles on them :rofl1:
The Dan
The Dude Abides
Vendor
Watertown SD
2009 ST1300 ABS
7982
I can't get mine to pop with air. Anyone have pictures of where to hook on to lift?
The Dan
The Dude Abides
Vendor
Watertown SD
2009 ST1300 ABS
7982
Thanks dduelin, I knew I saw that pic some where but just couldn't find it. That did the trick....
