Last weekend is did some minor maintenance on my 2004: replaced the front tire, changed oil, changed rear drive oil, replaced front pads. I drove the bike to work Mon and Tue with no issues. Wed the rear brake pads come in and I replace them. I was a little unsure that the left pad had seated correctly even though I was able to get them both bolted in. With the bike on the center stand I rotate the rear tire by hand, nothing out of the ordinary. I decide to test with the engine and it in gear. I start up the bike in neutral, all is good. I put it in gear and slowly let the clutch out and I hear a clunking sound. Not sure if it's coming from the rear tire or the engine. I shut it down, check the rear tire again, all seems good. I decide to not ride the bike until I find out what is going on.
Fri evening I do the same test and get the same result. I increase the rpm and it seems to either go away or is happening close enough together that it is less noticeable. I go through all the gears and get the same result. There isn't any more felt vibration than normal. I take a slow ride down the street and I don't feel or hear anything. NOTE: I have my helmet on and the whine of the engine is covering any other noise.
After reading some posts I decide to take off the rear tire to see if there might be something noticeable. I had read somebody had a similar problem and it was the cush-drive?? Not sure what that does.... I don't see anything obvious i.e. broken, metal shavings, etc. All the bearing feel smooth.
I also remove the final drive and it feels ok as well.
All that said, this is the first I've torn into a shaft-drive.
Any suggestions / thought? Questions or direction to go next?
thanks, as always for all of your help and input.
GJ
GJ
