sport_tourer said:Reinstalling the water pump chain should NOT be a problem. You should be able to easily slip and L-shaped tool (bend a screwdrive if you must) to resintall the chain around the back of the clutch basket. Then install the the chain around the smaller water pump sprocket, and then install the sprocket with the chain already in place back into its little hole. And dont worry about the water pump chain slop....when u reinstall the front cover, you will actually be alignining/positioning the water pump sprocket, which will take up tension, and all will be fine. I was really worried about this when I had mine apart, but had some Honda mechanics tell me no sweat, just put it together.
To me, the hard part after removing the front cover and messing around in there is the reinstallation of the front cover itself. Everything esle should be easy.
I wish the word easily was working for me! I have spend at least 15 minutes with the chain fished up to the top, but I cannot get enough slack to actually re-install the water pump drive gear. The lower chain run must be getting caught on some kind of protrusion.
For me the hardest part of this task is the the work position I am in. I don't have a cycle lift, so the bike is on the floor and I am bent over on my elderly knees and my back will only do this for so long before it cries 'uncle". Getting old is a bitch!
