ST1300 engine sounds like loud sewing machine
paulcb
Celina, TX
'97/'01 ST1100 ABSII
8735
I too like the sound of both the stock ST11 and ST13, although I'm a little partial to the ST11. My ST11 had Two Brothers slip-ons when I bought it. After a year of that noise, I couldn't stand it any longer and replaced them with a set of stock pipes. Now I can hear the motor... ;)
CA desert/Montana
2009 ST1300
326
The gear driven cam whine kind of grows on you. It's like air cooled Porsche engines, Ducati dry clutch rattle, and other iconic internal combustion sounds that I've come to savor.
Yes it grows on you but the 1300 has chain driven cams. The dual counterbalance shafts are gear driven.
CA desert/Montana
2009 ST1300
326
Hmmmm. I'll get to see this for myself here soon as I'm going to do my first valve clearance check. So is the whine from the gear driven counterbalance shafts? I like to know what I'm lusting after
8-BALL
GeriatricMutantNinja Norwegian
Des Moines, IA
ST1300 - NT700
7344
My S.O. thinks the ST sound like her Kitchen-aid mixer. Now When I start the bike up I am reminded of chocolate-chip cookies.
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
If properly adjusted, the counterbalancers should be pretty quiet, and the noise they make when out is a bit different than the engine.
In the back of the service manual, there's a nice cutaway illustration of the engine that shows how all of the power travels. There are a bunch of gears that carry it, all spur (straight-cut) gears. Those are what make Mr. Jetson's noise.
Helical gears are quieter but have a characteristic of applying axial forces to the shafts they're on and complicates everything from the bearings to the casings, adding weight to handle it. Switch to spur gears and all of that goes away.
--Mark
Wolverhampton UK
Adding to an existing thread rather than starting a new one on the same theme......
I was sat at a crossroads in my car the other day waiting for the lights to change when I heard a Pan pulling up.
I had limited view of the other roads and at first thought I was hearing things as the Pan has a very distinctive whine (which I find pleasing) and maybe I was just reminiscing about my previous ride.
When the lights changed sure enough there was a 1300 about 5 cars back on an adjacent junction.
It made me appreciate the distinctive sound of the Pan as a lot of bikes (apart from the "Blab Blab Blab" of Harleys) all sound the same.
Not our dear old Pans.
Just saying ......
Sadlsor
Birmingham, Alabama
2008 ST1300A
9065
I like the sound, the purring at times, the growling when on the throttle in higher rpms, and yes, even the "whine" if you want to call it that.
Reminds me of the private jets that fly over my back yard, coming and going from the small airport 6 miles from me.
I like all of the subdued ST sounds... there's already too much noise in my life.
JJames
Norway
2000 ST 1100 ABS II
I too like the stock sound , or the lack of it. Makes a enough noise at stand still on idle.
Fort Worth, Texas
91 ST1100/06 ST1300
I love the ST mechanical noises. Tells me everything is fine.
Our ST1100 has more road noise since I installed a taller windscreen. It varies with old tires/new tires and road surface.
Can't hear either bike at highway speeds.
Wolverhampton UK
Grrrowwll Grrrowwll !!
I wonder what it would sound like being ridden like that (before you get pulled over for being a "Bad Ass Biker "obviously).
If Tony the Tiger rode a motorbike it would be a Pan sans Mufflers......
