front RH caliper
...in every other respect they look identical. still stumped
Only that the lugs for the calliper bracket sit further outward... not obvious when looking at the from the side/profile, only when looking down while holding them vertically side by side... or when trying to install the non-ABS calliper...
southport uk
how right you are but an easy fix with a different caliper bracket all done and dusted , thanks everyone.
how right you are but an easy fix with a different caliper bracket all done and dusted...
Sure, simply throw the reinforced ABS-I/TCS calliper bracket on and go...
But: how are you now going to fix the non-ABS fork-brace (with M6 threads) to the RHS ABS-I/TCS fork-leg with the 8mm bores?? ;-)
Ah, so you've replaced both fork-bottoms... that info puts an end to the guesswork ;-)
southport uk
sorry yes i got the bike which had been in a slight front end hit ( bent forks ) so i replaced them and the steering stem just in case
