Winston Lee, Winston66, from Western Australia,
A question for the Guru's.
My 2003 ST1300 has recently developed a problem with the headlight operation, It is this.
When shutting down the bike after a ride , IE stopping the motor by turning the ignition switch to the off position , the headlights stay on, it does not matter weather either the hi or low beam is selected.
If the ignition switch is left in the off position and the start button is pressed again then the headlights will turn then turn off off.
If before starting the motor when turning on the ignition the headlights light up as normal, but then if the ignition is turned off without starting the motor the lights remain on until the start button is pushed then they will go out.
I have tried searching the relevant forums but have not been able to find any posts with this problem and most write ups seem to be too complicated and or technical for me to understand,
I hope that there is a simple fix for this.
Any relevant comments and or thoughts will be appreciated
Cheers to all, Winston Lee
Winston66, Western Australia
