- Joined
- Mar 18, 2006
- Messages
- 2,824
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
Removed
I'm writing about waypoints here. In basecamp on the tool bar there is a flag icon that's a user inserted waypoint tool (says it in the little help window when you mouse over it). You can change it's symbol to many different icons on the map when you open it up on the map. You can also relabel it and write in comments in the "Notes" tab.I think you may be referring to the things that Basecamp refers to as Shaping Points.
What I didn't communicate well here is when you have Basecamp set on Driving (which allows easier interstate routing) and the GPS is set on motorcycle. The GPS will try to run me off the interstate or main highway. Or Basecamp is set on motorcycle and the GPS is set on driving. In this case the GPS keeps trying to route me to much longer routes on back roads rather than the highway I've selected. I've started to use the custom setting in Basecamp for mixed interstate and motorcycle routes. This option has solved my re-routing problems.So does that suggest that because you have (say) motorcycle set on Basecamp, and the satnav has its own settings for 'motorcycle', which are maybe different, the route changes ? I don't use the custom route options, but instead I have customised the motorcycle profile in route options from the one that was set up initially. I'll keep an eye on that, but so far nothing has been recalculated, unless I have forced it to to see what happens.
There's still a lot I can learn about BaseCamp and the GPS. I've merely pointed out my experiences. I'm sure someone who delves into it can arrive at better conclusions and uses. I've read the New England Rider's site and learned some there.I'm not trying to prove anyone right or wrong here.
Several things you can try.but there is always a weird loop which seems pointless, when I try drag the route to the road I want it does not like it and will then draw a straight line (like a flight route) to my changed point.
1) When you have a route in mind, force it by inserting waypoints. BaseCamp's and the GPS will have programming in it that won't necessarily match what you have in mind.
2) The Driving activity with either the "fastest time" or "shorter distance" option selected will give a more direct route. There are differences in route selections between the fastest time and shorter distance options.
3) Make sure avoidance options aren't selected that exclude the section you want in your route.
4) To get rid of that straight line use recalculate route. Problem here is I've found my basecamp always goes back to it's programming and not my route ideas.
I've had two highway in the states that did this to me and I had to force it by plotting several close together waypoints. They were the Natchez Trace and WY 14a across the Big Horn Mountains. I'm sure there are many more all over the world that do this. I can't explain it but just work around the fault.I have gone through all the settings and the settings for motorcycling are set to fastest time and all the avoidances are unchecked and despite dragging the route in an attempt to get it to go where I want it either causes loops or the straight "flight line" I am describing. When I get the straight line and press recalculate it does not make a difference.
I had to do this in Kansas once to force the Garmin to take direct routes on some gravel/dirt roads to see some gypsum formations just off HWY 83. The programming in the activities driving and motorcycle just got confused. Frustrating. Had to use waypoints at every intersection and the destination.If I use the "truck" option the route works fine and it goes where I expected it to go.
Never experienced this. Can't guess why this is happening.I have emailed my points A to B directly to jfheath last night along with the screenshots as the file size allowed to be uploaded on here is too restricting and he could not get it to do what it did with me. One thing he did notice that when I plan points A to B two random road numbers appear.
You need to down load the same map you use in the GPS to BaseCamp. I've experienced some minor issues when they were different. My Garmin would recalculate the route no matter what I did in BaseCamp.Late last night I tried it again and it worked and I did not change any of my previous settings, one thing I did not mention is that when I am trying to calculate my route I have my Garmin plugged into my laptop to get the detailed maps I needed.
I've had my Garmin Zumo 550 GPS for 8 1/2 years and BaseCamp for what seems like 4 years. I've worked with my wife's 660 and BaseCamp for three years. Supposedly the Zumo 550 is not compatible with BaseCamp, but I've gotten it to work for me by keeping the maps sync'd and judicious use of waypoints. It's always gotten me to my destination even if it took me on a 50 mile detour once. And it's always gotten me home. I'd say you might want to practice on some on 80 km routes or about an hour ride. Go to some dives you always wanted to eat at. Plan one way as driving and the other as motorcycle. Play with some options on later trips. Take notes on what you chose and make sure to set the GPS to the same, see what happens. Don't have a bad experience on a long trip. Short trips in the country side are almost never bad.I will try something local to me before I go to Europe, the garmin Tutorial video is two minutes long, I have been sitting trying to get it to work for hours.!!!
One additional tip.I have gone through all the settings and the settings for motorcycling are set to fastest time and all the avoidances are unchecked and despite dragging the route in an attempt to get it to go where I want it either causes loops or the straight "flight line" I am describing. When I get the straight line and press recalculate it does not make a difference.
Very true. However, if you change the profile for activities, BaseCamp will ask if you want to apply it to all routes using that activity or the current route. BaseCamp is again is kludge here and asks in a way that's confusing. Several times I didn't pay close attention and ended up recalculating all my routes. Selecting "No" will retain the route settings but change the all Activities to Custom. It's one reason I've started using the Custom Activity more, BaseCamp messes with Custom less. It also means I have to use more waypoints. I really recommend trying the Custom activity and see how it works for you.I find it useful to look back at previous trips. I've learned the hard way that changing profiles causes all of your stored routes to recalculate and change.
Since a Basecamp update about 2 years ago my 660 has started a habit of spontaneously, randomly recalculating routes in progress even though I have it set not to do so. Since I don't know what the 660 is going to come up with during the recalc I typically reload the route in flight. Sometimes this will happen once per route, sometimes a half dozen times per day. I brought this up on the Zumo forum and got into a long discussion about it with someone from Garmin. In the end he changed tact and told be to go back to using Mapsource as the 660 is no longer compatible with Basecamp!?! Previous to that Garmin was saying we all had to give up Mapsource and learn Basecamp since Mapsource is no longer in development. I invested a LOT of time migrating everything into Basecamp. For the most part I'm happy with that direction. It is kind of nice to be able to superimpose previous routes while building a future trip. You end up having to invest a lot of time to insure you get the route you want, and you have to put up with random recalcs, but I feel there are enough benefits to go with Basecamp. I just get the feeling Garmin isn't coordinating the development of their hardware and software as well as they used too....Lots of additional points is better should the route be recalculated by the zumo. The route is only recalculated between the key points - whether they are waypoints, shaping points, alerting points or non alerting points. On the 590 i am beginning to use non- alerting points mostly, as they do not insist that you visit them in the same way. On the 660 it doesnt matter.
I don't want to change my Motorcycle profile to something else, I just want to use it for new trips, but retain the previous routes as they were. I guess changing the previous routes to profile 'custom' would retain those routes as they were calculated at the time they were created??Very true. However, if you change the profile for activities, BaseCamp will ask if you want to apply it to all routes using that activity or the current route. BaseCamp is again is kludge here and asks in a way that's confusing. Several times I didn't pay close attention and ended up recalculating all my routes. Selecting "No" will retain the route settings but change the all Activities to Custom. It's one reason I've started using the Custom Activity more, BaseCamp messes with Custom less. It also means I have to use more waypoints. I really recommend trying the Custom activity and see how it works for you.
That's what BaseCamp will do. It changes the activity to custom keeping the original settings of the route. There's an option under custom for selecting motorcycle, car, truck, ect.I guess changing the previous routes to profile 'custom' would retain those routes as they were calculated at the time they were created??
So do the forums say which Garmin units are compatible with Basecamp?I've seen Garmin forums that discuss how the Zumo 550 and 660 are not compatible with basecamp.
They did and listed just about every Zumo. Hard to believe the current Zumo's aren't compatible with BaseCamp. Since I don't have issues other than housekeeping between BaseCamp and GPS units, I don't believe what they're saying.So do the forums say which Garmin units are compatible with Basecamp?
I agree. I will also add that navigating Maps is no simple matter for programming, and the analog human brain can sort out routes on a map better than any programming(as of today). I've written here that sometimes the Garmin software just doesn't like a highway for what ever reason and you must force the issue with the waypoint tool for these errant highways. Looks to me like you found one of these highways; although, I could be wrong about your highway and waypoints may not fix it. Try the waypoints along the route, add a bunch, then start to remove one at a time and find the length of road Garmin doesn't like. It's tedious but it works for me and thankfully I've only had to mark two roads like this in the US so far.It wouldn't necessarily be accurate if it did , especially given the Garmin person's comment. The problem is that the software is evolving and people's experiences are based on what they believe at the time. The terminology is also very dynamic, even within Garmin. Look at their use of the termi 'Via Point' in the current zumo software for the 590 and the current basecamp software. They contradict each other. Its only a small point, but confusing when a forum post assumes one definition, and the reader assumes the other.
