Last weekend I finally decided to bleed the brakes since u had about 35k on them. I figured I'd do the pads and then bleed the clutch since I had most of the plastic off ( which is a whole nother story getting back on when the previous owner has dropped the bike a few times and bent most of the mounting brackets). Anyway, when I got done with everything I had horrible brake drag in the rear. I know I bled all of the air out and I know I did it in the correct sequence. I also took apart the SMC to make sure it was moving freely in the bore, and it was.
In the process of trying to find what was dragging, I rotated the left caliper up to apply the SMC, which applied the outer piston in the rear. Now my question is, when the SMC rotates up, it forces the fluid to the rear caliper but as it falls back down, does it get replenished from the rear master cylinder, or does the fluid get forced from the outer piston back through the SMC? Because right now, the SMC does not refill as it falls back to the neutral position, unless I press the rear caliper pistons in with a pry bar. Does this sound right?
Now my second question is, the only thing forcing the fluid back to the rear caliper is that SMC piston, if you took that out and then bled the brakes as normal, theoretically when you applied the front brakes, you wouldn't have a linked brake set up, right?
Brian
Brian
