They may have installed the new seal upside down. Don't ask me how I know that this might be the cause of the leaking.Snip ........ And the folk seal they just replaced, failed on the trip home
Sent from my D6503 using Tapatalk
Sometimes it's some dirt/grit that gets between the seal and the fork that causes a leak. Get a thin piece of plastic stiff enough to get down between the seal and fork and work it around and up. It might draw out the contamination allowing the seal to work again.Well I have replaced the rocker cover gasket and this seems to have helped with the oil issue! just need to sort the fork seals now.
It's a brand new seal I just had the garage fit it. I got 15 mins down the road before I saw it leak again. I've brought a genuine Honda kit now and will do it myself has its the easy side.Sometimes it's some dirt/grit that gets between the seal and the fork that causes a leak. Get a thin piece of plastic stiff enough to get down between the seal and fork and work it around and up. It might draw out the contamination allowing the seal to work again.
