I'd loose those monstrous bar-raisers and go for OEM mount... will bring back direct steering and front end feedback...
I'd also ditch the tires after that many moons outside...
Already replaced all that with stock components (thanks again, Mudduc!)...Josh said the risers were horrible when he rode it. Too much leverage for the rubber bushings, so they moved around a ton. He changed both tires before he parked it. The rear one has a bad spot where it's been sitting on dirt for a while so it's definitely getting changed. The front one looks really good still, but I might change it out anyways. Other stuff I've done..
-replaced all fluids (brake, clutch, coolant, engine oil, rear diff oil, blinker fluid)
-checked and adjusted valves
-replaced all coolant hoses and o-rings
-packed steering head bearings
-blew out all the dirt in the radiator fins
-replaced fuel lines and in line filter
-got rid of the fuel shutoff valve
-cleaned and dialectic greased the handlebar switch housing contacts, and took the ignition switch apart for the same treatment
-cleaned and lubed the side stand cause it was stiff as hell
-sanded and polished all the scratches and gauges out of the windshield
-painted and cleared all the gray trim pieces
As it sits right now, it's ready to roll, other than the rear tire and all the Tupperware. I've scuffed all the plastics down for a color change. Josh is charging me $200 for the materials and painting everything for free (as long as I help him wet sand it, lol). Impatiently waiting for him to get around to painting it, so I can get the dang thing legal and shook down in time for our 7 day Arkansas trip on the 1st of June!!
Frank
