2010 ST 1300a 25000 miles. Just got new tires. K&N Air filter. Aftermarket Cruse control.
Problem I noticed this weekend:
the bike is missing slightly and dying when I pull the clutch in at low rpm.
but my thoughts are as follows:
Dirty air filter not likely, just put it in last year, but will check. checked and it was clean
Vacuum air leak?
Going to replace the check valve for the Cruse control, I removed it last year.
Idle is ruff and rather low at 700 rpm, looked for the knob to adjust, will find when I pull the plastic.
Thanks for the help.
Vacuum air leak?
