ST1300 right side headlight is out
Salt Lake City, Utah
2006 ST1300 PA ABS
I'm out in Grand Junction Colo and doing some work here for a few days but i just noticed the right side head light is out. After removing the bulb it looks ok and replace it with a back up and again no luck. I don't have any manuals with me so I'm looking for some hints. Is there any fuze that controls one side of the head lights? and is so where is it. I have never had an issue with any lights before so I'm kinda looking for some help.
Thanks for anyone posting some advise or directions.
Mantaray23
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000145
5901
Re: ST1300 right sid headlight is out
The fuses are located behind the left side cover, along with a bunch of relays. You have two banks of fuses and you'll have to look through to see if one of them are blown. I looked in the manual and the owner's manual and couldn't find a diagram of the fuses, but if you look though them, if one is blown, it should be apparent. There is also a possibility it is a relay, so if you don't find a bad fuse, you might have to look at those.
Good luck. Tomorrow, I'll be tearing my 2012 apart to FARKLE it, at that time I can probably figure out where the headlight fuses are.
Scooter
This space for rent...
Germantown, WI
2019 BMW R1250RT
5929
This schematic of the headlight system should help you out. But judging by your avatar it looks like you have a police model so there might be some differences.
Just for perspective, when you say right side headlight, you mean as sitting on the bike and not looking at the headlights from the front, correct???
Mantaray23
2006 ST1300 PA ABS
Sorry i didn't make that clear. Looking at the front of the bike looking directly at the headlights it is the right side.
So it is the Left headlight. Did you test the new headlight bulb? I've run across dead bulbs in new packages. If your tupperware is off, you can use a voltmeter on the connector to determine if the whole circuit is dead or just the low beam. The wiring diagram will make troubleshooting much easier. Never having delved into this problem (this circuit), I'm sorry I cannot help more.
Ada ( Grand Rapids ) Michigan
'07 ST 1300 & '91 GW
8421
The High and Low beam relays run the LH ( Port side ) headlight bulb only . The Hi/Lo switch takes the current to the RH bulb and Hi & Lo relays trigger circuit(s) only , that run the LH & hi beam indicator in the dash) ( I know , it's bizarre and no reason the relays shouldn't power both bulbs like they do on my GoldWing , while taking the current load off the Hi/Lo switch)
Scooter
Germantown, WI
2019 BMW R1250RT
5929
Check fuse G if you have a non ABS bike, fuse I if yours is the ABS version...
Alief, TX, USA
7461
Scooter's post (#3) should tell you everything you need to know, unless you have an ST1300P model (I have no idea what the differences might be in the headlight circuitry).
FWIW, removing and reinstalling those relays is a real PIA. Takes a lot of patience, trust me.
Aurora, Colorado
It's typical to blow left headlight bulbs. I've gone through a number of them, but have never had a right headlight bulb go bad. I agree with the comment that your replacement bulb might be bad. Try exchanging the right bulb with the left bulb and see if the trouble follows. That'll tell you for sure if it's a bulb problem.
Mantaray23
2006 ST1300 PA ABS
i tried the bulb replacement first but i "assumed" by backup bulb is ok. I will switch the bulbs around and see if the problem follows the bulb. If it follows the bulb then thats a easy answer. The tupperware is not off and the bulb is fairly easy to get to without removing it and yes i have a ABS Police model.
Thanks for all the hints and directions I'm working on it..and i will find the answer.
Mantaray23
Mantaray23
2006 ST1300 PA ABS
Final update. With the help of everyone pointing me to the direction of the fuses, as i have never needed to find them... really hate to admit that but its a true fact. Anyway after reviewing the two sets of fuses and removing them i did find one blown. After replacing the fuse all is working as designed. Guess i better put my manuals out on the net so i can find them in the future. Also will have a set of backup fuses.
Thanks to everyone who assisted me with this ...... issue.
Mantaray23
The Owner's Manual (not the Service Manual) is legally available free online from Honda as a pdf. I downloaded it and keep in on my phone and iPad and computer.
Great idea! Can you tell me where you found it? That would save me some time looking on Honda's website. Where did you store it on your phone? (Iphone or otherwise? - What app?)
I don't remember the link but I'll take a look. I downloaded it to my computer then emailed it to my iPhone. When I opened the email I used the Share button/icon to send it to iBooks. There are probably apps that are better at navigation pdfs but iBooks is already on the phone.
EDIT: I took a quick look at Honda's site as I've been through the hoops before and the downloads section is closed for repairs (redesign actually). I'll see if I can put a copy in Drop Box and PM you a link. That will probably be later today.
Mantaray23
2006 ST1300 PA ABS
update. After replacing the fuse not it blows about one a day. Not sure of what steps to proceed with to determine if its a charging issue, battery issue or something else. No additions/changes to the bike in over a year. don't have any gear to test the output of the alternator.
Any ideas or suggestions?
Scooter
Germantown, WI
2019 BMW R1250RT
5929
I suspect a wire chafing issue of some kind. Check out this thread for one possibility...
st11ray
charlotte, nc
'06 ST1300
7189
The owners manual is only good for setting your clock! If you want any useful info on the bike you better have the service manual with you.
