Any after market clutch lever options ?
Vancouver,BC Canada
1992 ST1100
The clutch is killing me-while under way it's ok to shift-but at a stop sign or red light ,having to hold it in for an extended period of time-my hand hurts like hell. Finding myself having to put bike in neutral to rest hand-not a fan of doing this-prefer keeping bike in gear. Are there any after market clutch levers or a clutch one can cannibalize from another bike-perhaps with a different design over stock ?
cheers
British Columbia
2021 RE Meteor 350
Not sure that a different lever is going to make any difference on the tension exerted by the hydraulics in the clutch. Some people change the lever for another (sorry, can't remember which) because they find the reach is too far for shorter fingers. No doubt, sitting for more than a couple of minutes does get tiring on the hand, especially doing it a lot in stop and go traffic. I could say you will get more used to it as time goes on too, but in slow traffic, I often click into neutral for the rest. I'm not sure if you have had a hydraulic clutch on your previous bike(s), but you don't need to pull the lever more than about a half inch to release the clutch.
MURFREESBORO, TN
18 Gold Wing
7285
I installed an adjustable clutch lever off of a VFR on my ST1300 and it works perfectly. Not sure if it would work on the St 1100. You could compare the set up by looking at one at your local dealer.
San Diego (Carlsbad, Solana Beach)
ST1300 2004
what?
Try sliding your hand outboard so that your pinky and ring fingers are on the bar end weight, and your two strongest fingers are holding the end of the lever which naturally provides the most leverage.
Fwiw I'm in neutral before I even bring the bike to a halt, preferably from 2nd to N, and I don't drop it back in gear until the car in front of me is actually moving.
Peoria, Illinois
1995 ST1100
8866
I do the end of the lever trick for extended clutch-in holds, and also the Nuetral postion, but preferably only once there's a car at a full stop behind me. Otherwise I like to leave it in gear too as the OP prefers.
You can also add a little grease to the contacts points of the lever and the pin - it helped mine a lot and made it a touch smoother and easier to work.
Auckland, New Zealand
8901
There is a post here in which CBR1100XX Blackbird levers have been used.
The ST1100 clutch lever is shared with the following models, and there are adjustable levers for things like the PC800 on ebay (http://www.ebay.com/itm/Honda-PC800-Pacific-Coast-89-98-Black-Adjustable-Upgrade-Clutch-Lever-/180730714269?hash=item2a1463d89d:m:mmbS58mVHuootdDAKLjOZjw)
This Honda 53178-KE8-006 LEVER, L. HANDLE is used on these models and components:
1982 VF750C A CLUTCH MASTER CYLINDER
1982 VF750S A CLUTCH MASTER CYLINDER
1983 CB550SC A CLUTCH MASTER CYLINDER
1983 CB650SC A CLUTCH MASTER CYLINDER
1983 VF1100C A CLUTCH MASTER CYLINDER + CLUTCH CONTROL LEVER
1983 VF750C A CLUTCH MASTER CYLINDER
1983 VF750F A CLUTCH MASTER CYLINDER
1983 VF750S A CLUTCH MASTER CYLINDER
1983 VT750C A CLUTCH MASTER CYLINDER
1984 CB650SC A CLUTCH MASTER CYLINDER
1984 CB650SC AC CLUTCH MASTER CYLINDER
1984 CB700SC A CLUTCH MASTER CYLINDER + LEFT CONTROL LEVER
1984 CB700SC AC CLUTCH MASTER CYLINDER + LEFT CONTROL LEVER
1984 VF1000F A CLUTCH MASTER CYLINDER
1984 VF1000F AC CLUTCH MASTER CYLINDER
1984 VF1100C A CLUTCH MASTER CYLINDER + CLUTCH CONTROL LEVER
1984 VF1100C AC CLUTCH MASTER CYLINDER + CLUTCH CONTROL LEVER
1984 VF1100S A CLUTCH MASTER CYLINDER + CLUTCH CONTROL LEVER
1984 VF1100S AC CLUTCH MASTER CYLINDER + CLUTCH CONTROL LEVER
1984 VF500C A CLUTCH MASTER CYLINDER
1984 VF500C AC CLUTCH MASTER CYLINDER
1984 VF500F A CLUTCH MASTER CYLINDER
1984 VF500F AC CLUTCH MASTER CYLINDER
1984 VF700C A CLUTCH MASTER CYLINDER
1984 VF700C AC CLUTCH MASTER CYLINDER
1984 VF700F A CLUTCH MASTER CYLINDER
1984 VF700F AC CLUTCH MASTER CYLINDER
1984 VF700S A CLUTCH MASTER CYLINDER
1984 VF700S AC CLUTCH MASTER CYLINDER
1984 VF750F A CLUTCH MASTER CYLINDER
1984 VF750F AC CLUTCH MASTER CYLINDER
1984 VT700C A CLUTCH MASTER CYLINDER
1984 VT700C AC CLUTCH MASTER CYLINDER
1985 CB650SC A CLUTCH MASTER CYLINDER
1985 CB650SC AC CLUTCH MASTER CYLINDER
1985 CB700SC A CLUTCH MASTER CYLINDER + LEFT CONTROL LEVER
1985 CB700SC AC CLUTCH MASTER CYLINDER + LEFT CONTROL LEVER
1985 VF500C A CLUTCH MASTER CYLINDER
1985 VF500C AC CLUTCH MASTER CYLINDER
1985 VF500F A CLUTCH MASTER CYLINDER
1985 VF500F AC CLUTCH MASTER CYLINDER
1985 VF700C A CLUTCH MASTER CYLINDER
1985 VF700C AC CLUTCH MASTER CYLINDER
1985 VF700F A CLUTCH MASTER CYLINDER
1985 VF700F AC CLUTCH MASTER CYLINDER
1985 VF700S A CLUTCH MASTER CYLINDER
1985 VF700S AC CLUTCH MASTER CYLINDER
1985 VT1100C A CLUTCH MASTER CYLINDER
1985 VT1100C AC CLUTCH MASTER CYLINDER
1985 VT700C A CLUTCH MASTER CYLINDER
1985 VT700C AC CLUTCH MASTER CYLINDER
1986 CB700SC A CLUTCH MASTER CYLINDER + LEFT CONTROL LEVER
1986 CB700SC AC CLUTCH MASTER CYLINDER + LEFT CONTROL LEVER
1986 VF500F A CLUTCH MASTER CYLINDER
1986 VF500F AC CLUTCH MASTER CYLINDER
1986 VF700C A CLUTCH MASTER CYLINDER
1986 VF700C AC CLUTCH MASTER CYLINDER
1986 VT1100C A CLUTCH MASTER CYLINDER
1986 VT1100C AC CLUTCH MASTER CYLINDER
1986 VT700C A CLUTCH MASTER CYLINDER
1986 VT700C AC CLUTCH MASTER CYLINDER
1987 VT700C A CLUTCH MASTER CYLINDER
1987 VT700C AC CLUTCH MASTER CYLINDER
1989 PC800 A CLUTCH MASTER CYLINDER
1989 PC800 AC CLUTCH MASTER CYLINDER
1990 PC800 A CLUTCH MASTER CYLINDER
1990 PC800 AC CLUTCH MASTER CYLINDER
1991 ST1100 A CLUTCH MASTER CYLINDER
1991 ST1100 AC CLUTCH MASTER CYLINDER
1992 ST1100 A CLUTCH MASTER CYLINDER
1992 ST1100 AC CLUTCH MASTER CYLINDER
1992 ST1100A AC CLUTCH MASTER CYLINDER
1993 ST1100 A CLUTCH MASTER CYLINDER
1993 ST1100 AC CLUTCH MASTER CYLINDER
1993 ST1100A AC CLUTCH MASTER CYLINDER
1994 PC800 A CLUTCH MASTER CYLINDER
1994 PC800 AC CLUTCH MASTER CYLINDER
1994 ST1100 A CLUTCH MASTER CYLINDER
1994 ST1100 AC CLUTCH MASTER CYLINDER
1994 ST1100A A CLUTCH MASTER CYLINDER
1994 ST1100A AC CLUTCH MASTER CYLINDER
1995 PC800 A CLUTCH MASTER CYLINDER
1995 PC800 AC CLUTCH MASTER CYLINDER
1995 ST1100 A CLUTCH MASTER CYLINDER
1995 ST1100 AC CLUTCH MASTER CYLINDER
1995 ST1100A A CLUTCH MASTER CYLINDER
1995 ST1100A AC CLUTCH MASTER CYLINDER
1996 PC800 A CLUTCH MASTER CYLINDER
1996 PC800 AC CLUTCH MASTER CYLINDER
1996 ST1100 A CLUTCH MASTER CYLINDER
1996 ST1100 AC CLUTCH MASTER CYLINDER
1996 ST1100A A CLUTCH MASTER CYLINDER
1996 ST1100A AC CLUTCH MASTER CYLINDER
1997 PC800 A CLUTCH MASTER CYLINDER
1997 PC800 AC CLUTCH MASTER CYLINDER
1997 ST1100 A CLUTCH MASTER CYLINDER
1997 ST1100 AC CLUTCH MASTER CYLINDER
1997 ST1100A A CLUTCH MASTER CYLINDER
1997 ST1100A AC CLUTCH MASTER CYLINDER
1998 PC800 A CLUTCH MASTER CYLINDER
1998 PC800 AC CLUTCH MASTER CYLINDER
1998 ST1100 A CLUTCH MASTER CYLINDER
1998 ST1100 AC CLUTCH MASTER CYLINDER
1998 ST1100A A CLUTCH MASTER CYLINDER
1998 ST1100A AC CLUTCH MASTER CYLINDER
1999 ST1100 A CLUTCH MASTER CYLINDER
1999 ST1100 AC CLUTCH MASTER CYLINDER
1999 ST1100A A CLUTCH MASTER CYLINDER
1999 ST1100A AC CLUTCH MASTER CYLINDER
2000 ST1100 A CLUTCH MASTER CYLINDER
2000 ST1100 AC CLUTCH MASTER CYLINDER
2000 ST1100A A CLUTCH MASTER CYLINDER
2000 ST1100A AC CLUTCH MASTER CYLINDER
2001 ST1100 A CLUTCH MASTER CYLINDER
2001 ST1100 AC CLUTCH MASTER CYLINDER
2001 ST1100A A CLUTCH MASTER CYLINDER
2001 ST1100A AC CLUTCH MASTER CYLINDER
2002 ST1100 A CLUTCH MASTER CYLINDER
2002 ST1100 AC CLUTCH MASTER CYLINDER
2003 ST1100P A CLUTCH MASTER CYLINDER
paulcb
Celina, TX
'97/'01 ST1100 ABSII
8735
I bought a set of these off Amazon. The clutch is adjustable in the same manner as the the brake.
paulcb
Celina, TX
8735
They even match the color of my bike!
Yeah, they're pretty much identical to the stock ST11 brake lever, with the same 2 position adjustment.
Grand Junction, Colo.
92 ST1100
For YOUR safety alone, not a good choice or option. Get some 50+yrs. of riding under your belt and your thought process and choice will change......hopefully;).
Suggest to him where you think he erred in his thought processes and choice so he won't have to wait 50+yrs for enlightenment.
92 ST1100
Please help me out Brant... I really need it because I only have 42+ years riding under my belt. Thank you.
Well, no help, as that is plenty enough yrs. behind the bars to know not to leave it in neutral at stop lites.......especially in those high traffic locations out that direction:).
ST1300 2004
what?
Why? So I can stare at my mirror looking for someone who is about to rear end me? And then I'll release the clutch and squirt away just in the knick of time? And because I'm already in gear I'll have the time to execute this maneuver? Ok thanks for the lesson, and now let's please bring on all the old war stories of how many times you saved your own life by doing exactly this (and please don't exclude the times you panic popped the clutch and stalled it, or launched into the bumper of the car in front of you, or shot out into cross traffic, or missed the light because you were looking in your mirror, or pulled up between cars for no reason at all, or clipped your mirror or hard bag trying to thread the needle, or got halfway clear duck paddling at 1 mph and still got rear ended).
99% of threats are between your 10 and your 2. Brothers... I say keep your heads up. Just one man's opinion.
paulcb
Celina, TX
8735
+1. I'm with you... I put it in neutral at stop lights too. Although, out of habit, I check my mirrors every time to see what's coming to a stop. Once there, it goes to neutral if all looks OK. IMO, the chances of keeping it in gear and then using that to successfully avoid getting hit from behind are very close to zero. Too many other bad things can happen keeping it in gear. IMO, it sounds good on paper but not in everyday life. I've commuted in stop/go traffic everyday for several years and I've never needed to be in gear to avoid a situation. There are only so many things we can do to mitigate our risks when riding, else we should just cage it everywhere.
I keep the bike in gear at stops for one reason: one a few occasions (a few too many though) I twist the grip the bike makes noise and I go nowhere. It's a rookie mistake made because all my riding career I never put the bike in neutral at a stop. A lot of unlearning to do so I keep it in gear. If I need to adjust something or get something out of a pocket I go back in gear afterwards.
Because of the span of the lever to grip distance my hand gets sore quick in stop and go traffic. That makes holding the clutch in at a stop a little tiring.
I got these: http://shop.the2wheels.com/index.php?route=product/product&product_id=533&search=adjustable+clutch+lever and always get a good grip on the lever instead of just by my finger tips. My hand is less tired and holding the lever in at a stop is now no big deal.
My V65 Saber and V61 Interceptor both had hydraulic clutches and I was able to get direct replacement dog-leg non-adjustable levers that were comfortable. I never found that option for my ST.
8901
I had a spare adjustable OEM clutch lever from my 1999 VFR800, and that fitted the ST1100 like it was made for it. That means any aftermarket part that fits my VFR, will also fit the ST, so there is a huge range to choose from.
