How Many Miles On Your Original Alternator?
finger lakes ny
1999 ST1100
7959
103K on the 91. Problems 2 years ago on a trip. Have since done some wiring changes learned here, and is ok at the moment, but leaking a little oil.
99 is fine.
shomann
Minneapolis, MN
ST1100
Mines leaking a bit of oil too. Makes me a bit nervous about a long trip if it's coming from the alternator.
kiltman
Stratford, Ontario Canada
2002,ST1100ABS
8826
My 1990 quit after 174K km but has had a transplant by the new owner with a 40amp conversion and we hope it goes for many more miles.
Paris, TN
'99 ST1100
8606
1999 40A alternator failed at 96K miles due to broken winding wire in the rotor. I have spare fields, diode bridge and voltage regulator
Hamilton Ontario Canada
1990 ST1100
New life in your old horse now. The 40A I put in is putting out 14.2 V :) Yeah!
I wonder if anyone want the old 28A alternator with the drive gears?
JPKalishek
Armadillo Kicker
Menominee, Michigan
2 '91 ST 1100
Monday, while out riding, the original 28 amp on the two tone died. 105,000 miles.
100,000 on the Black (failing memory edit: I replaced the original alternator after it cracked so there is around 50,000 miles on this alternator) and it is going to need a connector repair.
hartlepool
97 st1100
150k miles on original 28 amp alternator, but I think it is giving up, started leaking about 5k ago. at idle test meter shows 14.2 volts at battery(so new battery fitted last one 5yrs old).I read somewhere that alternator only starts charging at 2000rpm mine show charging at idle?? now if I switch the headlights on the idle speed drops only use to happen when cooling fan kicked in. so looks like 40 amp up grade needed. unless somebody can point out an alternative solution
