Broken Rear Frame
Seattle area
2016 FJR1300ES
265
RobbieAG
Robert
Greensboro NC
flexes ?????
If I grab the Givi rack and move it forward and back, it flexes maybe a sixteenth of an inch. There is no play left to right. Does this sound normal? It's not just the rack that flexes, but the whole rear section, plastic and all.
finger lakes ny
1999 ST1100
7959
Mine is solid.
STraymond
Cincinnati Area
'01 ST1100
8700
RobbieAG
Robert
Greensboro NC
I just took it apart and here's what I found (frame extension mount):
- 1 missing short bolt
- 1 loose short bolt
- 1 long bolt with missing nut (found it in toolket compartment)
- 1 loose long bolt
Good thing I checked! It's off to the hardware store tomorrow to get a bolt.
And I'd regularly inspect all 4 bolts holding the subframe to the backbones for proper torque, as their known to come loose over years and years of (too heavy) topcase-rattle...
A torque wrench and a drop of thread-lock deals with the issue
I tried to find these but wasn't sure exactly sure where to look. I didn't see it in the manual either. Any hints?
West Michigan
'98 ST1100
8470
Martin :
I doubt if I'm carrying more than 22 lbs. But when I have time, I will re-enforce the bracket on both sides. Why take a chance ??
Fort Worth, Texas
91 ST1100/06 ST1300
Just a note - The Hondaline trunk for the ST1100 moves 'around' on the rack. The first time I installed one I thought I'd made an installation mistake. Sort of like the saddlebag 'flop' - built into the design.
First ride after I installed mine, I noticed a rattle and found it coming from the top box that was bouncing around a bit on the bracket. So I used a 1" wide strip of sticky backed insulation foam stuck around the perimeter of the bracket. The box still has a little give relative to the bracket but no longer rattles.
RobbieAG
Robert
Greensboro NC
Is this linky what you're looking for?
I think this may be closer. I believe ST1100Y is referring to to where the subframe bolts to the frame.I'm not sure those bolts are accessible with what I have removed. I might wait and check them next time I have the rest of the plastic off.
Jim,
you're a role model there ;-)
I've seen STs loaded so hefty, that their rested on the rear tire once the owner finally managed to hulk the rig onto the main-stand...
You believe correct...
The two forward ones (bold inserted from the outside, nut attached inboard) can be accessed from the "tool-compartement" once the seat is removed.
To get to the rear ones (only bolts, each attaching into a threaded sleeve, welded into the frame tube) one must remove the tailcone (thus carrier plate and passenger handles must come off too)
RobbieAG
Robert
Greensboro NC
- 1 loose long bolt
I got the missing bolt, torqued everything and used some Loctite. It's much more solid now.
finger lakes ny
1999 ST1100
7959
Just what bolts are you guys referring to? As far as I know, the tailpiece that the rear assembly/racks bolts to, is a welded part of the frame;
The "subframe" is up front beneath the engine.
finger lakes ny
1999 ST1100
7959
Got ya !...Seems to be a problem with the wording. You guys are simply referring to how the PLATE, CENTER GRAB RAIL mounts to the tail of the frame via 4 bolts? No subframe involved.
...how the PLATE, CENTER GRAB RAIL mounts to the tail of the frame...
And now enter this as thread title and see how it goes... ;-)
(I once tried an -MT3- part number reference as title... uh-oh... :lol: )
RobbieAG
Robert
Greensboro NC
I was a bit confused. There is a subframe (FRAME, SUB part number 50150-MT3-000) which is on the bottom of the main frame. The part in question is "PLATE, CENTER GRAB RAIL" (part number 77313-MT3-000) which is the one that cracks and the bolts tend to get loose on.
