Redneck nut cooler
london
How's this for an idea. Remove the side fairing mount the scoop under the headlight with a tube into the area under the tank. Lift the tank and attach foil reflective to the underside but not right to the edge. Put some washers on the tank bolts to create a gap around the tank. Cold air will feed under the tank pushing the hot air up and out around the tank. I insulated my previous pan with foil but it blocks too much heat in but it's good for keeping the seat cold
