Also who said you had to lube that joint? The drive shaft to rear end spline joint seem to go forever without any service, mine has.
How many miles on yours?
29K. Read my previous post LINKY for the whole story. Both the dealer's mechanic and Kevin said they felt nothing while turning the rear wheel (checking the u-joint - i.e. no looseness or identifiable wear in the u-j). Both test drove the bike and heard the clunk. Kevin located the clunk w/ his stethoscope at the forward end of the pumpkin w/ the bike on the center stand and a helper blipping the throttle.
Hmmm, been a long time since I had mine out but I don't think you can pull the ujoint off the engine pulling the pumpkin with the drive shaft coupled. I doubt you can pull the pumpkin WITHOUT the drive shaft coming out of the ujoint. In fact it would be nice if the ujoint would detach that way then you could change it out without dropping the swingarm (but it won't happen).
It's OK if the driveshaft comes out of the ujoint, that's how it goes together. It is a bit tough to get back together at times, just hold your mouth right and keep stabbing.
This is what I obviously want to avoid, if possible. See below.
that spline is small I don't think it would cause much of a clunk, any unusual vibrations along with a clunk could be a u joint. Check the wheel to hub splines and the rubber insulators . Noises can carry, check your basics. It has to come off anyways.
Kevin suggested that I replace the rubber bumpers as a prophylactic measure - they are relatively cheap and easy to do while I have the wheel off. And I will be changing the rear tire at the same time.
I pulled that final drive assy. off my ST110 at 180 K miles, and it came off clean. The D.S. stayed with the engine.
It fit real well in the engine spline, and didn't try to pull out.
Not the EXACT same assy. as the 1300, but very similar, & should come apart the same way.
This is what I want to hear (grin) but I will deal with whatever happens.
OK - another idea. The Honda Manual shows the splines at the u-joint being relatively long (the pic is not to scale but I'm guessing a 2" engagement in the u-j?). It also shows the pumpkin-drive shaft spline to be short and fat. There is a boss on the pumpkin that fits into the swingarm. Does anyone who has had theirs apart think this scenario is possible: I'll remove the pumpkin bolts and pull it rearward to clear the boss. Once the boss clears the swingarm, I'll have a helper try to grab the drive shaft with needle nose pliers (heavily taped to protect the d.s. and swing arm). If there is not enough room (i'm hoping at this point the forward splines are still engaged in the u-j) for the needle nose, I'll use a taped screwdriver. The whole object here is to try to get the shaft to remain in the u-joint and come apart at the pumpkin.
If all these shenanigans fail, I will indeed fiddle with the d.s. and get it into the u-j on reassembly. I'm simply trying to plan ahead to minimize more work.
