Would suggest you start here; http://www.partzilla.com/parts/search/Honda/Motorcycle/1993/parts.html or http://www.partzilla.com/parts/search/Honda/Motorcycle/1993/ST1100+A/FRONT+FORK/parts.html90K and was planning on checking steering bearings and replacing fork oil but a leak has sprung so a rebuild would be appropriate.Anybody have a parts list of what I need.Assume seals,bushings,etc,...
Thanks
Michael
Thanks for the help Terry and taking the time to post the links.Would suggest you start here; http://www.partzilla.com/parts/search/Honda/Motorcycle/1993/parts.html or http://www.partzilla.com/parts/search/Honda/Motorcycle/1993/ST1100+A/FRONT+FORK/parts.html
As for the parts, if just the seal has blown then you really just need new oil seals (32 x 2 in the parts diagram) and new oil. To disassemble the forks you need to remove the damper bolt at the bottom and that has a copper sealing washer (44 x 2), I've reused these many times but you may want to fit a new one. You will need a litre of 10W fork oil. If the fork has never been rebuilt, you can add new inner and outer bushings (13 x 2 and 14 x 2) as well.
More importantly, take a close look at the fork stanchions before you reassemble and you may find a rock dent with raised edges that has cut the seal. Gently file any high spots away before your put it all back together.
No you don't need those. The seal stopper is a spring steel circlip, infinitely reusable unless you lose it. The fork cap o-ring likewise should be fine to re-use endlessly.Thanks for the help Terry and taking the time to post the links.
What about #28 Oil Seal Stopper and #48 O-Ring?
Michael
