I have a 2007 ST1300. Bought it 5 moths ago. Have been riding 930 miles (1500km) without problems.
The brake fluid has been changed by a shop 2 months ago.
Yesterday when i started the bike it managed to have the wrong gear in and it stopped immediately.
When i started it again and started to go the ABS lamp never went out as it usually does. Rode for a while and made short stops and turning of the ignition. ABS lamp still lights up and is lit all the time when i drive.
I followed this tip but i dont get any error code. The lamp is always lit. Even if i take out the fuses.
http://stwiki.notonthe.net/twiki/bin/view/ST13/ABSQuickGuide
The ABS rings on the wheels has no damage and i cleaned the sensors. The gap from sensor to ring is also ok.
I have measured the front and rear sensor with an ohm-meter, both have 1006 ohms in one direction and endless resistance in the other.
Could it be air in the brake fluid? Or is it some fault with the controller, since i dont get any error codes and the lamp is lit all the time it might be this?
Is there anything else to check?
Confused rider.......
