Bump out bottom of windshield 1 inch ST1100
Versailles, KY
2018 GL1800 Airbag
8693
Has anyone devised a method of using spacers to bump out the bottom of the windshield an inch or so on an ST1100?
Ron
Orlando
ST1100s
2432
I have not nor do I know of anyone that has. May I ask what are you trying to accomplish?
Uncle Phil
4 ST1100(s)
002064
698
Obviously you would need longer screws and plastic spacers (probably Home Depot or Lowes would have them). My concern would be that the extra 'leverage' might pull the rubber wellnuts out or crack the garnish and/or bodywork. MadStad Engineering made an 'adjustable' windshield for me. I don't know if they still do or not -
http://www.madstad.com/s.nl/sc.7/.f
Uncle Phil
4 ST1100(s)
002064
698
I bought a Rifle windshield insert for the Connie. Check that out. Easy install. Even came with a special drill bit just for plastic.
Rifle used to make windshields for the ST1100. I had one for a while until I broke it. I don't know if they still do or not. Other options are the Laminar Lip if turbulence is the problem.
jspringator
Versailles, KY
2018 GL1800 Airbag
8693
I'm going for the Madstad effect. It is a pretty common mod for the 1300. Madstad won't make one for the 1100, and I can't find a used one. I tried longer screws and washers and couldn't get it to line up.
Ron
Orlando
ST1100s
2432
Yea. You're making the windshield radius larger by moving it out but you're not moving the windshield holes to compensate.
jspringator
Versailles, KY
2018 GL1800 Airbag
8693
That explains it. The fix would be to secure the top 2 screws and the center bottom screw. Line up the spacer with the well nut mark the appropriate spot that lines up with a Sharpie, and drill a new hole.
You could snug it down some, but since the angle of the windshield would no longer match the angle of the screw, you couldn't torque it down.
Some sort of thick rubber washer or half washer may work. Anyone have any other ideas to let you snug it down?
I think we're close!
East Anglia, England
ST1100X
#1702
Do you mean something like this? Nothing like an original screen, but that's how I did mine. Rubber tap washers are good.......
Roger
Moweaqua, Illinois
2005 Concours
UP....I bought a Laminar Lip for the Connie, because of turbulence. It worked for that problem. However, I now have a very high pitched noise as a result. I'm not sure if it worth it.
