I have bought myself a Honda marine voltmeter to install in place of the headlight adjuster, and I plan on installing this over the weekend. I have bought a small fused relay and will wire the VM through that direct to the battery, triggered off a switched power source. Is there a good reason not to connect the VM light to the main meter feed? All my other lights are permanently on in any case.
I recall seeing a picture where the adjuster had been relocated maybe into the front of the left hand storage pocket? Is that a good place (I rarely use that pocket anyway) that leaves the adjuster functional or is there a better way? I have seen a diagram of the police model where the adjuster is clipped to the right upper frame tube.
