Rear brake pads replacement
Cicero, IN
2019 Tracer 900 GT
I am replacing the rear brake pads. I have them in and am putting it all back together. I am having a problem reinserting this rubber boot. The question I have is, how do you do it?
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
The pointier end of the boot (left side in your picture) should be inserted through the caliper from the inboard side and then the caliper needs to be attached to the rest of the assembly.
The way I usually do it is pull the axle out far enough for the whole thing to be freed up and leave the caliper in place.
--Mark
BigBrownsFan
Cicero, IN
2019 Tracer 900 GT
That is good information. But I didn't remove the caliper nor the axle. Is it critical to reinstall?
Yes! you must have this grommet in place for the caliper to slide and float on, or the brakes will lock up.
ESB
STRIDER
Oklahoma
'07 ST 1300
The only thing I've ever disassembled from that rear caliper is the Pin that holds the brake pads in.
Have no idea what that rubber boot is for. Never taken it off.
If you get online any of the parts diagrams will help it make sense. The solid part plugs into the caliper body, and the sliding dowel slips inside the female part. You will find two sliding pins on the rear caliper assembly. One is bigger than the other.
sky.high
Calgary
The Honda of the day
9052
You'll have to separate the fixed part of the caliper that hold the pistons from the floating part put the bushing back into the pin and reassemble, not a big deal but as others have said it should not have come out, is it damaged ?
When you reassemble put some high temperature caliper grease on the pins
Make sure its rubber friendly HT caliper grease.
Lost in the sticks
2007 ST1300
I have been using sil-glyde from NAPA on the caliper boots with success.
It will not cause swelling of the rubber boot.
Wasaga Beach, Ont. Canada
'04 ST1300 Blue STar
Hah,, I did the same thing today. When removed,, I found the right hand side of the rubber pin boot (as pictured) is missing. Also,, the back surfaces of the worn out aftermarket pads show they were mislocated at some point,,, ie: two distinct contact positions for the pistons on one side,, and the fixed caliper on the other. It never ceases to amaze me when I discover work done poorly by PO's and their elected dealerships. I will get the boot on order tomorrow. Cat'
[h=2]BOOT, PIN BUSH (NISSIN)[/h][FONT=&quot]45132-166-016
[/FONT]
I pulled it out. I thought there was a bolt head under it. I know, pretty dumb!
Sent from my iPad using Tapatalk
