Make sure its rubber friendly HT caliper grease.You'll have to separate the fixed part of the caliper that hold the pistons from the floating part put the bushing back into the pin and reassemble, not a big deal but as others have said it should not have come out, is it damaged ?
When you reassemble put some high temperature caliper grease on the pins
I pulled it out. I thought there was a bolt head under it. I know, pretty dumb!How'd the bushing come out if you didn't remove the caliper?
--Mark
Sent from my iPad using Tapatalk
