Homemade Hydration System
So here is my version of a foot peg mounted hydration system. Simple but effective.
Ashley
What are you using to secure the 'bottle' to the bike? I think you have it resting on the rear foot peg, and is that black sleeve strapped to a tip over guard (Bygdawg's?). Where did you get the hose and bite valve? I saw some on ebay....
Peter
Uncle Phil
4 ST1100(s)
006403
698
That's an ST1100 so they sure ain't Bygdawg Tipover bars - unfortunately (I surely wish they would fit at ST1100 without a lot of 'bodywork' changes!). :D Good job, my friend. Is the can u-bolted around the rear foot peg?
Ashley
Ashley
Jacksonville, Florida USA
2020 Africa Twin
4906
I need to take some better pics of this. However, I'm leaving in the AM headed to ON-STOC. The black part is a coffee can that happens to be about the right size to hold my Igloo jug. I removed the rubber part of the passenger foot peg and drilled two holes in the can to match the holes in the foot peg. I took a piece of 1/8" flat aluminum stock and cut to fit under the can to reinforce it some. Found some longer SS bolts at the ACE hardware and bolted the can to the peg. Drop the jug in and add a small bungee cord on the back side to prevent jug from bouncing out. The clear tube came from ACE as well and it is tucked under the seat to keep it from flopping and I added a Camelbac drink spout thingee to the end. I need to come up with something to insulate the drink tube but haven't had time. Will report back in two weeks.
Jacksonville FL
06 ST1300A
8729
That's real similar to mine. After you take a drink just blow the water in the tube back into the jug so the next time you take a drink it's not hot water.
Muskoka, Canada
FJR & Super Tenere
4759
Nice Ashley.
The Camelback 90 degree bite valve I bought came with an insulated hose. Camelback stuff isn't the cheapest tho but I've never found that neoprene(?) hose insulator stuff anywhere else. If anyone has I'd like to know about it. Mine is wearing out.
Also - mounting on the left side or right side of bike? I put mine of the left side for 2 reasons - shorter hose run up to my left hand, and less chance of me kicking it getting on/off. However I see most(?) people have them mounted on the right. Left side mount makes it more difficult to put bike on center stand tho - but still do-able
010688
When I use a similar system I just blow ambient temp water back into the container then pull a cold slug through. No need to insulate the entire tube.
Advice given to me was to buy hard frozen ice for the morning fill up or top off of the container. Hotel or gas station drink station ice is barely frozen but hard ice lasted me an entire 24 hour plus day in 95 to 106 degree temps.
Ashley
Ashley
2020 Africa Twin
4906
Jeff, I mounted on right side, most I have seen were on that side and I'm right handed and I have cruise control, sooo... Right side. I stole a bite valve off an old camelbak I had lying around so no insulation. I'll figure something out or use the ole blow back method as everyone mentioned.
Dave, good advice on the ice but where does one get hard frozen ice?
gmast1100
Gettin old sux
Blairsville, GA
2016 Kawasaki Versys
297
Jeff-IIRC I got the neoprene hose off of Amazon. Go there and search for drink hose cover. I have a Olympia jacket that has the water bladder in the back of the jacket and needed the neoprene to cover the hose. I think they even had different colors?
T_C
St. Louis, MO
2005 St1300
8568
t hard frozen ice?
Nothing to do with temperature, it's all in how it is created.
Hard ice is what comes put of most people refrigerators. It is ice that is frozen form the outside in, expansion is limited so the internal part when it freezes it is under pressure. Your home fridge does this. That's the white part you see inside the ice cube. It's denser and harder then the clear part on the outside.
Commercial ice production (like in a drink machine) is made with falling water. The water is recirculated and continuously cascades down a grid wich is cooled below freezing. Slowly the water freezes onto the grid and fills in the holes. Since the ice cube only freezes from one side it is not forced into solidifying under compression. Thus the term, soft ice. Then they momentarily reverse the freeze section and warm the grid, the ice pops out and that is the crash sound you occasionally hear.
But it is all water frozen at (generically) 32?
Blocks of ice will last longer but not get the surrounding medium as cold as smaller pieces of ice.
Ashley
Ashley
2020 Africa Twin
4906
Learn something new every day.
010688
I found it plentiful at gas stations where an 8 lb bag is $2.00 or so, fill up the cooler once in the morning and stuff the rest of the bag in my suit against my chest. A bag would last a tank of gas in 100 degrees F.
Muskoka, Canada
FJR & Super Tenere
4759
Anything sealing the spout and tube to keep out road debris and to keep the tube inserted?
Where the tube passes thru the cooler lid I have a rubber grommet which does the trick. Grommets are easy to find for not much at Lowes, Home Depot etc. On the drinking end the bite valve keeps things clean, mostly.
The fit was so tight I saw no need to seal. We shall see.
If needed the cooler spout could be rounded with a file and some neoprene tubing cove stretched over the tubing and spout like a gaiter over a fork tube.
