For those of you who haven't seen my posts in the ST 1100 carb section, I've been working on getting my '92 ABS running again after 7 years of sitting with the intention of selling it. However, during the process of going through the carbs and getting the bike running again, I started to have second thoughts and was thinking I'd just keep it and put the extra work back into putting it on the road. Well....I've made my decision. After putting it all back together and going for a 20 minute ride, I've decided to keep it. ('Don't think the wife was all that pleased with the decision, though.)
Even though it was a short ride, I fell right into the old routine, though U-turns were slightly sketchy. The bike ran well enough considering I did not sync or tune the carbs and I may have a vacuum leak as the carb boots are a bit on the hard side. Rolling on the throttle didn't give me the same rush of acceleration as I remember but I'm hoping new boots, a good sync, fresh plugs and air filter and a carb sync and fine tune will take care of that. It also needs new rubber, fresh brake and clutch fluid, fresh coolant, plus new rotors and pads. And the forks need new seals and fluid. Probably time for a valve lash check as well. It was great to be back on the road.
So, I'm capable of doing all the work but I have a question....what rubber should I buy? I was a big fan of Metzler's Z6 Interacts but I hear some are not made in Germany and they are problematic. So, what are you guys running nowadays? And remember, I've got the odd rear size of the 1100's.
Also, since I'm shopping for new rotors, who can you recommend in that department?
Cheers to all!
Martin
Cheers to all!
Martin
