Just turned 100,000 miles
Littlestown Pa
St 1300 2005
100,000 miles on my 2005, runs as strong as when new. A bit of valve noise at 3100 rpms,
Wasaga Beach, Ont. Canada
'04 ST1300 Blue STar
Congrat's on hitting the 100k mark,,, and I am sure your STeed will double or even triple that eventually. Interesting about the valve noise. I am nearly the same mileage,, and so have begun to listen to my engine a bit more lately. Would the tendency not be for the valve clearances to tighten over time ?? I suppose, and exception that might cause a bit of extra clearance and resulting noise would be cam lobe wear ?? But I would not expect that in a modern Honda engine. Cat'
Littlestown Pa
St 1300 2005
The ticking sound starts at 3100 rpms and lasts only about to 3300 rpms. If you run it to 31 thT00 and keep it there you can hear it good. I'm just wondering if the other guys hear the same thing which would make it the nature of the beast. By the way have never had the valves checked...it just runs so incredibly good. Thanks for the reply.
When the bike is dead cold, adjust the counter balance adjusters and see if your noise goes away.
W0QNX
Blacksheep Tribal Member
Pensacola, FL. USA
06/ST1300 19/R1250RT
007437
Good on the 100,000, bad on never checking the valves. It probably will run smooth right up to the valve burn day. Valves usually "tighten up" over time until there is no more clearance between the moving parts. So it probably gets quieter sounding the longer you put off the check-adjustment. You really should check the valves.
Littlestown Pa
St 1300 2005
Omg never touched it. My cousin fooled with his on his 04 and he said it helped. Have to investigate. THANKS
