The third filter that has the filtration holes and nut covered came with Honda tool fluted for filter removal.
Sent from my SM-G928F using Tapatalk
I don't know what the 1300 filter looks like, but maybe you were given the wrong one. Just to be clear, I think this is the wrong one.Thanks again bush. I always use OEM parts on my bikes. You think it may be that I'm in the UK those other 2 are showing the nut and no holes? Doesn't seem right to me either. They are both in honda genuine packaging and the one with the cover and holes came loose but has Honda logo etc. Purchased from fowlers in Bristol UK that deal with all OEM parts.
Cheers mate.
OK mate, this is what I found at a USA parts web site. The one above is the correct filter, but the part number is different than my quoted part number because it also comes with the removal tool. Hope that helps clarify the part number difference. For the Honda part only, without the tool, you should be getting a 15410-MFJ-D01. You are up rather late over there!Part Number: 15010MCEH51
ST1100A1 - OIL PUMP
Is for the one with nut covered and 8 filtration holes.
Yes there are led light on the front. Can they be easily removed from wiring.What a Beauty!
I can't make out any cracks.
Do I see some LED lights on the front of the Belly pan?
Why remove them? I think it would be a great safety feature.Yes there are led light on the front. Can they be easily removed from wiring.
