Gents and Ladies,
I have searched, but I am unable to find the answer to my questions so far. So, new thread is in order. Due to all of your great knowledge. I am sure someone will have the answers.
Q1: Inside the clutch MC, there is a little clip of sorts that is pushed into the center. I recently bled the clutch line and had to remove some gunk from the MC. upon doing so, that little clip came out. On the clip is a flat tab. Is that tab supposed to lay flush with the bottom of the MC, or is it raised?
I put it back in raised and need to know if I made a mistake. Easy enough to fix, but it seems to be operating as expected in this position.
Q2: I lost all pressure (resistance) in the clutch. Upon checking the MC, the level was low. I added new fluid and this did not resolve the issue. So, I checked the line. no cracks. I checked the slave and found a leak, but it was the weep hole. Cleaned it up and bled the system. The fluid is now clear and the pressure is back. However, I still see that it is weeping. What problems are associated with a weeping clutch?
I am guessing possible seal issue with the piston inside the slave, but don't want to go diving into the project only to find out it is safe and sound. Thoughts?
Thanks again for taking time to read and provide feedback. Everyone on here has been especially helpful.
Wade
Wade
