Upt' North, flyfisher,
I will have to leave this for spring as I just moved to a new house as I had to vacant the previous one due to the owner coming back from abroad.
In the new place I don't have a garage and unfortunately my bike will have to stay outside the front door if I don't manage to persuade the landlord to let me get the bike in the living room
I couldn't check if the spark plugs are tightened as I need to take the fairings off as my spark plug wrench doesn't fit underneath the fairings
I have taken out the cable to see if all of the spark plugs are working. After taking the cables out one after the other all of the spark plugs seem to work, at least that
While working on this i noticed a distinct smell of un-burnt fuel and checked at the exhausts. The one on the left side facing the direction of travel (cylinder 1 and 3) seemed a lot richer which means I will have to do the Starter Valve Sync as well.
I also checked the U joint, which is fine but my rear brake is dragging and I will have to check the SMC when spring comes as well.
The bike pulls to the right so I will have to re-torque the front. I will combine it with checking the mounting bolts, after Santa brings me my torquing wrenches
My list for the spring service is now almost ready
Thank you all for the support. I will come back and write all of the findings so people can benefit from my experience. I'll make pictures if I don't forget about it.
All the best,
WhiteSparrow.
