kiltman
- Joined
- Apr 27, 2013
- Messages
- 3,282
- Age
- 68
- Location
- Stratford, Ontario Canada
- Bike
- 2002,ST1100ABS
- STOC #
- 8826
2 shots in the dark. When you fill up and remove the gas cap is there a swoosh of air escaping? If not you may have a faulty gas cap. This can affect fuel delivery.
the second is that it could be electrical, have a look at the red wire going into the main relay on the left side, make sure that connection isn't compromised. Another spot to check is also on the left side by the green connector for the side stand, is a main red power wire just inside the up member of the frame. On my bike the insulation wore off due to vibration and rubbing on the frame which could ground out depending on the condition.
These are remote possibilities but very easy to check
