Heated grip controller question
Kenly NC
07 ST1300A(P)
7649
So, while my 13 is down, I started looking at other stuff that needs repair.
I broke my hondaline grip controller while working on something else, and of course, you can't buy just the controller anymore. Has anyone tried using one of these?
http://lockitt.com/Lockitt/product/EHOX696HS.html
Or this?
https://www.denniskirk.com/moose/replacement-controller-0631-0021.p595468.prd/595468.sku
Then I found this:
http://www.ebay.com/itm/Manual-Dimmer-Switch-for-LED-Strip-Light-12V-8A-Mountable-with-Terminals-/251985183083?hash=item3aab7cc16b:g:8IMAAOSwEzxYXXCx
Which, from my research makes me believe it would actually perform the same function, and I don't see the grips pulling more than 8 watts.....
I have zero experience with these things, so I'm looking for something that will be relatively easy to install.
Norm
Vendor
Chilliwack, B.C., Canada
KLR650
8030
The eBay LED controller is good for 8 amps. I've used them for years for grip heaters and all sorts of things. I pull the little board and rheostat out of the box to save space. It's simple to extend the three wires to the pot if needed. They seem to be a very low heat circuit so have covered them with a small baggie and tape.
Ozzie
Kenly NC
07 ST1300A(P)
7649
Ok. well for 4 bucks, I think it's worth rolling the dice. I don't really need the push button and flashing lights, I'm fine with a rotary dial. I'll glue something over the original hole and just use the guts to save space. I would like an led to indicate on or off, not sure how I would do that, hopefully google will be my friend. I'm really rusty on this kind of stuff. Took me 4 hours to wire a motion detector into my laundry room so the light goes on when you walk in, I got tired of walking across the room to turn the light on, previous owner didn't add a switch at the inside door. dunno why, it's an added on room, would have been easy during construction, now, not so much. Log houses are a pain for adding wiring, I had to get really creative when we remodeled the bathroom, but I ended up with a kind of chic industrial look.
Ozzie
Kenly NC
07 ST1300A(P)
7649
My biggest thing is, will they work with the hondaline grips, but I believe I'm just overthinking it.
Norm
Vendor
KLR650
8030
Sorry to be so long in responding.
An LED us simple to include. I use one with a series resistor so that it doesn't light until nearly 12 volts. I keep a pile of them around for various projects.
