Fuel float, upper tank.
Dave.David
Rider
SB California USA
05,ST1300-04VTX1800R
8938
Hi smart people. Seems my float of the fuel sending unit is bad. It's a small cylinder, tube looking thing. Any one know what car used the same one? I have a 04 ST1300 so I'm thinking a Honda civic 04 or similar. Any thoughts? I wonder if the bottom tank uses the same float? I'd rather not buy the whole sending unit. Thanks folks.
Nova Scotia
'07STA
7235
How do u know it is bad. I thought mine was bad because it went from 3 bars to flashing. I removed the upper float and measured the ohms. I cannot tell u what it was. It showed as being bad. I cleaned the resistors on the float with denatured alcohol. I then remeasured and it was fine. That was 2-3 years ago. All is fine
Sent from my SGH-M919V using Tapatalk
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
What makes you think that's the case? The ST doesn't have a history of float failures; everything we've seen so far have been electrical, where the wiper meets the resistive strip. Tdinova's the only one I know of who's tried to clean it. If that works, it's worth a shot if you don't want to replace the whole part. Be aware that the float arm is delicate and if you bend it while trying to fit a new float, the entire sender isn't going to work properly.
That would be the 2001 Honda NoSuchAnimal. :) The only parts I know of that the ST shares with Honda's cars are fasteners. The fuel sender is an ST1300-specific part and an entire assembly, so the only place you'd be able to get a replacement float is by scavenging one from another used unit.
There is no float in the lower tank; see this page for an explanation of how the fuel gauge in the 1300 works.
--Mark
Vernon BC Canada
09 ST1300
I would just replace the whole assembly - it shows as under $70.00 at Ron Ayers, seems not worth the time fussing with trying to source the float itself.
Kenly NC
07 ST1300A(P)
7649
Since when has that stopped anyone on this list? :D
Dave.David
Dave.David
Rider
SB California USA
8938
1. When I pull the sending unit out of the bike the float was heavy. At that time I cleaned all the contacts and checked the contacts were connecting throughout the entire up and down motion.
2. When I put fuel in the bike next it shows full and then quickly sank back to three bars and never came back up. I have filled tank again and again, still no "full"
Dave.David
Dave.David
Rider
SB California USA
8938
--Mark[/QUOTE]
Thank you, I appreciate details like this.
Blrfl
Northern Virginia
Fast Blue One
4837
We don't have certificates we send out when someone's the first to have a problem, but we'd send you one if we did. :)
If you come up with any insight into how your float filled up, please pass it along.
--Mark
Blrfl said:
We don't have certificates we send out when someone's the first to have a problem, but we'd send you one if we did. :grin:
That made me laugh! Maybe a new badge to go with it?
Maybe pull the float and drain it then drop it a glass of water or rubbing alcohol and look for bubbles? One of the carb floats in my 305 Scrambler developed a leak in a seam IIRC. I thought I'd solder over it and be done. Don't recall why but I just bought a new one/set.
Dave.David
Dave.David
Rider
SB California USA
8938
Maybe pull the float and drain it then drop it a glass of water or rubbing alcohol and look for bubbles? One of the carb floats in my 305 Scrambler developed a leak in a seam IIRC. I thought I'd solder over it and be done. Don't recall why but I just bought a new one/set.[/QUOTE]
The metal is so thin on those carb floats I doubt they can be soldered at all.
I'm headed to a mc junk yard this week, see what I can find. If not I may try to find just any float about the same size, it may be hard to find one that I can
get on the rod in same way.
get on the rod in same way.[/QUOTE]
I have not touched my fuel float but some that I've seen (cars and light truck experience) are not hollow - they used a solid closed cell foam float. Maybe you could make one? I would suggest something that does not dissolve in gasohol. (You could make jelly in the tank if it did - not good).
Jacksonville Fl
2004 ST1300
Mine was bad on my 04 when I first got it four years ago with 20k on it. Bought two used ones from late model low mileage wrecks. Still have one as a back up. 30 shipped? Let me know if you are interested.
Dave.David
Dave.David
Rider
SB California USA
8938
Fuel level gauge, what's up with that.
Any one seen something like this? The fully full light rarely comes on and only after a complete top off , but off in less then a mile. Top Two bars are off at 37m, and 3 bars down by 69 miles.
So I get 200 miles or so showing half a tank then wow, 3 miles of first bar flashing, 22 miles till empty. Wait, half a tank for about 3m. No, 3m of 34m till empty. Back to Half a tank. So I fill up, 6.1 gallons, 1.6 gallons still was in tank. ***???? HELP
Blrfl
Northern Virginia
Fast Blue One
4837
Re: Fuel level gauge, what's up with that.
Sounds like the fuel sender in the upper tank has failed. Not unusual for bikes of that vintage, and not difficult to fix. One person managed to clean up the contact surfaces; most just replace it.
--Mark
