iPhone as GPS?
Re: I phone as GPS?
007 said:
Anybody upload pre-prepared custom routes (with lots of waypoints) into Navigon?
I'd be interested in that as well. I've had the app since v.1 but have only used it for Point A to B. When Apple Maps came along it was much easier to use and I never had a problem with it.
What I'd like be able to do is drag and drop a few pins as waypoints from A to Z and RTB. Then like a loop of string just drag bits here or there reshaping the loop. Then the app would recalculate as needed.
Shuey
Niceville, FL
FJR1300 ES, 2018
SPOT
LINK
7005
I've been using a waterproof case for my iPhone 4 and now my iPhone 5s from BioLogic. Absolutely waterproof and easy to use.
http://www.thinkbiologic.com/category/cases-and-mounts
I use my iPhone to run Waze most of the time to see what's ahead. Works best in populated areas, not so well in the middle of nowhere, USA. ;)
If one of BioLogic's mounting options doesn't suit your needs, I've made an easy adaption to mine for use with a RAM mount system. It's an easy change and very cheap. There's some discussion on this thread also about where to buy and other options that might be of interest. Even though the info is 4 years old, it'll get you looking for the best deal available.
https://www.st-owners.com/forums/showthread.php?124628-BioLogic-Waterproof-Phone-Case-Weds-RAM-Diamond-Back-and-Ball&highlight=BioLogic
Good luck,
Shuey
