Mirror housing straps
Norfolk UK
Hi, I took off my left and right mirror housings having found the safety straps weren't attached to the fairing panel. I own a 1997 ST1100 UK model and I cannot see where the plug end of the strap goes. There has been a similar posting showing a slot, but my panels do not have this. Any ideas? Maybe I just have to drill a new hole? Thanks, Dave Norfolk UK
Dave.David
Rider
SB California USA
05,ST1300-04VTX1800R
8938
Thick zip ties.
Tacoma, wa
I had a '98 and no holes for the corresponding retaining plug/connection. Either reusable or single use zip ties. To anything available inside the covered area. Or deeper to the frame inside.
British Columbia
2021 RE Meteor 350
Or just fuggedaboudit. Took those off both of my 1100's soon after obtaining them and never lost a mirror cover - yet (20 years). If the circlips are all in good shape, it isn't going to wiggle itself off and if the bike goes down the mirror cover won't roll away, if tethered, but it will still be toast.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Uncle Phil beat me to it.
Enroute to the firST NESTOC at Albany, NY, I hit something at speed on I-94 in MI and pranged the front rim and rear shock. And both mirror cover/signal modules were saved by those straps. Ya never know.... FWIW YMMV
Montreal
2009 ST1300A9
Same as John for me when I had an St1100. I hit a bad bump at speed and the right side mirror broke loose but because of the strap it stayed with the bike and was not damaged. I just stopped, popped it back on and continued. I`d say keep them hooked up.
kankakee
R1200rt
Wrong, hit a small bird on the interstate knocked it off but still hung there .... no damage
Norfolk UK
Phil,
That's it, problem solved. Thanks for the photo, it all makes sense now. Best wishes from the UK. Dave
Uncle Phil
4 ST1100(s)
002064
698
Maple Valley, WA
2001 ST1100
8294
The strap is also useful when your bike is parked and some careless person bumps/snags the mirror housing as they walk by. DAMHIK.
