Reginald
cyclepoke
What is the spec for the two bolts on the thermostat housing?
I found specs for a thermostat flange bolt at 9 lbf-ft but I don't know what a thermostat flange is. Why does the manual put the flange in the torque specs but not mention the thermostat housing. Also 9 lbf-ft sounds a little high for those small bolts, I'd have thought 6 lbf-ft.
If you've replace your thermostat what torque did you use?
I'd like to start putting the bike back together now.
