Help re-installing front suspension
crosari2
Toruk Makto
Valrico, Fl
2000 ST1100
Ok. Just finished cleaning forks. reinstalling new seals and new oil on my 2000 st abs. I have a manual that provides basic instruction and saw a few videos on Youtube on basic fork installation. U researched the Suspension Forum but can not find any discussion in great details and and tips on this topic. Is there any lengthy discussion that I've had might missed? Any tips are welcome.
crosari2
Toruk Makto
Valrico, Fl
2000 ST1100
Any tricks to help alignment of front wheel, sequence of tightening bolts, any tricks, better way of doing job better manual.
finger lakes ny
1999 ST1100
7959
FORK INSTALL
- Tighten Lower TT pinch bolts 36ft lb 432 in lb
- Tighten Upper pinch bolts 17ft lb 204 in lb
- Tighten Fender bolts 9 ft lb 108 in lb
- Tighten Anti dive 34 in lb
- Fork cap 14ft lb 168 in lb
FR WHEEL INSTALL
- Wheel on, axle nut loose
- Bounce/rock on CC
- Tighten axle nut 65 ft lb
- Tighten R pinch bolts 16 ft lb 192 in lb
- Tighten caliper mount bolts R 20 ft lb 240 in lb L 240 in lb/9 ft lb 108in lb blue loctite all
- Off CC
- Pump forks, brake on
- Tighten L pinch bolts 16 ft lb 192 in lb
- Don?t forget wheel spacer on R side and speedo drive L side
- SPEEDO NOTCH GOES BEHIND THE FORK NOTCH
- snug the pinch bolt, torque the axle nut, then torque the pinch bolt
- banjo bolts 25 ft libs
STraymond
Cincinnati Area
'01 ST1100
8700
What Dean said, except on the forks, tighten the caps prior to the Upper Pinch Bolts (the ones right by the caps).
Grand Junction, Colo.
92 ST1100
DeanR has that sequence down correctly;) Pay particular attention to that second portion of sequence, with the first two being MOST important for correct trackability. First two of second portion, climb aboard bike, hold front brake(hopefully calipers installed) and rock bike back and forth fairly aggressively compressing suspension somewhat. This centers relationship of forks, then tighten and torque in sequence DeanR has shown. This method of centering of forks has been used for several decades in the moto-x world for decades, as I was one, and at one point a few decades ago semi-professional in that arena.
crosari2
Toruk Makto
Valrico, Fl
2000 ST1100
Thanks DeanR, STraymond, Brant. This clarify the sequence much better. I also have a piece of aluminum to put under tire to make easier on tire movement. Will get it done tomorrow.
FR WHEEL INSTALL
- Bounce/rock on CC
- Off CC
- Don’t forget wheel spacer on R side and speedo drive L side
Dean, was this a typo? At that point the axle bolt, and all pinch bolts have been torqued down. After the L side pinch bolts, you're done, right?
crosari2
Toruk Makto
Valrico, Fl
2000 ST1100
Done. Thanks to all members who offered comments. Now to the rear suspension (when CO approves funds).
