Clutch problem
Vernon BC, Canada
2007 ST1300
8025
After being parked over the winter I moved my 07 ST1300 out of storage and started some maintenance. When I got around to the clutch lever there was no resistance. The oil is clean and full but when I put the bike in 1st and pulled the lever in the bike would not move. I did pump the lever many times, bike not running, pushing it in 1st gear with the lever in, but the tire would not move.
Put it on the center stand and started the engine, shifted to 1st gear with the clutch lever in but the tire took off.
All was OK when parked.
Friday I will bleed the clutch fluid and see if there is oil pressure when I work the lever.
Any suggestions???
Bill
Lacombe, AB Canada
05 ST1300
Had that exact same problem 2 years in a row. The first time i figgered 'oh no, now I've got to change the clutch master cylinder, but maybe, just in case, I'll bleed it first'. Sure enough, I bled it and voila, problem solved. Next year, same thing, except for the 'oh no' part. I just bled the clutch system and it's been fine since then, 3 winters ago. Doesn't make any sense to me at all why it does this.
Pembroke, Ontario, Canada
7220
Hi Guys,, must be the season for clutches,, I started mine up today after a long winter's nap and same thing, no clutch action. In the fall I changed the oil with a synthetic, first time with it, Mobil 1 - 5W30.
It's -6C out and not looking to ride but wondering if it's just a bleed of the clutch or did I use a wrong oil.
Thanks for your help.
Peter
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
There must be a small air leak somewhere
The only place in the closed part of the system where there's an intentional vent to the air is the slave cylinder, which has a path for fluid to leak out if the piston seal fails. The best guess I can come up with is that something happens where the seal leaks just enough to let air through but not so much that the fluid escapes. Could be something as simple as the air side of the seal drying up and shrinking.
I had the same thing happen a couple of times and now make a habit of giving the clutch lever a few squeezes a couple of times a week as I pass by in the garage. That prevented it last year; we'll see what happens when I pull it out this year.
--Mark
near Harrow, Ontario, Canada
'83 BMW R100RS
8870
--Mark
Agreed Mark. Hydraulics were my thang when I was in industry and from my experience, there are several things that hydraulic systems do NOT like:
1) Dirt: clearances between components are extremely small and thus, tolerances are very tight - so any foreign matter in the system is bound to mess things up; (NOTE: tolerances and clearances are not the same thing at all);
2) Water: causes corrosion which leads to crap floating around - see 1) above;
3) Sitting idle for a long time: seals get hard and can leak. Sometimes they come back and sometimes they don't. It's best to exercise the system periodically even when it is out of service, just to keep things fresh. Giving your brake and clutch lever a squeeze or two during the off-season for just that reason is a good practice.
Blrfl
Northern Virginia
Fast Blue One
4837
The engine oil and hydraulic fluid in the clutch lines don't have anything to do with each other.
--Mark
'83 BMW R100RS
8870
Yup - totally separate systems.
However, as I understand it, some synthetic engine oils can cause your clutch to slip because like most bikes, the ST1300 has a wet clutch which actually runs in the engine oil.
So, when you say "no clutch action" - do you mean that the clutch is slipping or that pulling on the lever does not disengage the clutch?
Blrfl
Northern Virginia
Fast Blue One
4837
That's true of oil in general, dino or synthetic. The energy-conserving formulations have additives to make them slicker, and we've seen a couple of riders here get bit by that.
--Mark
Correct me if I am wrong, but did you say you used 5w-30 oil?
That would be the wrong oil! If you look at the bottle see if it says energy or resource conserving etc. If so get it out of there asap to save your clutch.
--Mark
There is another source for air to enter the system...both master cylinders have vent holes in their caps, and while this is above the rubber diaphragm, moisture can collect on the top of the rubber and it can be sucked down into the housing enough to leak air around the edges.
.02
Blrfl
Northern Virginia
Fast Blue One
4837
True, although the only failure there that would suck air into the closed part of the system is loss of enough fluid to uncover the hole at the bottom of the reservoir.
I suppose it's also possible for the piston seals at the master cylinder to leak some air if they shrink, too.
--Mark
T_C
St. Louis, MO
2005 St1300
8568
Hi Guys,, must be the season for clutches,, I started mine up today after a long winter's nap and same thing, no clutch action. In the fall I changed the oil with a synthetic, first time with it, Mobil 1 - 5W30. Peter
Ohh.. good call Larry.
Yes, 5W30 is Resource Conserving. This is not wet-clutch compatible oil. Look at the API Service Symbol (aka the doughnout) on the back of the bottle. Bottom part of the circle is what you don't want to see.
7220
Arrrgghh,, Thank you gentlemen,, it does say exactly that,, Resource Conserving!
So,, if I drain it out and replace with non RC oil will it have any residual effect or will it go back to normal??
Geeeez,, try and save the world and ..........
Sent from my iPad using Tapatalk
7220
Sounds good, kinda thought that would work. I'll report back. Had to tuck her back away yesterday, snowed again here. She won't see the sun for a couple of weeks. Hopefully April warms up!
Thanks again for all the help.
--Mark
I don't think I explained it very well (tired) When the black rubber starts getting sucked down inside the master cylinder housing (we've all found that at least once before) the moisture contaminates the fluid and allows the moisture to enter the system. This could be how the SMC and the PCV end up with air and crap inside them so often.
I would pick up some (Dino) diesel oil in 15w-40 wt. any brand (shell Rotell T, Chevron delo 400LE, Mobil Delvac 1300) etc. and change out the RC oil right away ( don't let it sit for a few weeks) You don't want your clutch plates soaking in that oil, as it will absorb into the clutch discs and cause them to swell and get slippery. Run the bike to get the bike hot, then strap the clutch lever down, this will open the plates and allow more oil to drain, then drain the oil and replace the filter, then fill it with the diesel oil. Run the bike a while then do this again. The diesel oil has alot of detergents and stuff in it, and will do a good job at cleaning everything out.
