ST1300 Double Dark Side
Peoria, Illinois
1995 ST1100
8866
How hard do you ride? Curves or straight mostly? Road surface - chip seal or nice smooth concrete?
Sent from my XT1575 using Tapatalk
It varies, probably pretty close to 50/50 around-town-country to 70mph interstate. We have some rough potholes in town, but the interstate is good. How hard is hard - at times I lean it over, but I try to keep it reasonably over the speed limit.
ST-V4ever
Linden, MI or Sebring, FL
'16 or '08 Goldwing
Took it for a high-speed spin and I could tell it was out of balance due to the grinding off rubber. (the dealer balanced it when it was mounted)
So, a little RideOn (16 oz for this tire) and another 12-ish mile freeway run and she's smooth as silk now. [emoji16]
Camarillo, Ca
2006 ST1300A
002552
I finally went double dark, I am on my second rear CT which now has 28k miles. The front MC tire only lasts about 10k. Tried to get a BT-45 but ended up with a Kenda 130-70-18 bias tire at 41 psi. I am still running and liking 28 psi in the rear. I have about 600 miles on the new front tire and I definitely noticed that it is much smoother going over those nasty parallel grooves and slab offsets. It does have a slight whine at medium speeds caused by the tire groove pattern.
San Antonio, TX
05 ST1300 Burgundy
8958
What tire did you go with? How many miles do you have on it now? Did you have to sand or file anything down to make it fit?
Cold Lake, Alberta
2008 Honda ST1300
Hi Tom.
I've removed my rear wheel off my 2008 ST and have my 205/50/17 car tire ready to mount tomorrow. I cannot imagine this tire fitting this bike! How was it to install back on the bike?
greg_in_npvl
V65 Rider
Chicago 'burbs
2003 ST1300/ST1300A
-snip-
Twas a little snug getting it past the pumpkin. I gently pushed forward and got it to pass. Once past the pumpkin, I had no rubbing on either side of my tire. Bear in mind my tire is the General Altimax. YMMV.
Sent from my VS995 using Tapatalk
Cold Lake, Alberta
2008 Honda ST1300
Hey Doug
I'm ready to have my 205/50/17 Hankook Ventus v12 Evo K120 car tire installed on my 2008 ST. Is that the same tire you went with? I sure hope so, cuz this one looks WAY too big to fit.
Camarillo, Ca
2006 ST1300A
002552
BF Goodrich G-force Comp-2 tire. After 40,400 miles it was time to get a new one. Went on tight but NO rubbing. Running at 28 psi.
Camarillo, Ca
2006 ST1300A
002552
Yes, you are correct. I did not worry about it too much since I never ride in the rain. In So Cal it would be suicide to do that with all the cages that have no treads. Can not do anything about a hydroplaning cage.... If you look at google maps of LA during a rain storm there are a lot of red dots where people had unexpected meetings. I just have to drive my truck on the 10 days that it rains here.... But when I had the new tire mounted I pointed out that the previous was mounted in the wrong direction.. So the new one is correct....
