Hello gents, need some expertise. I want to hook up one of those Kuryakyn voltage meters. I was hoping to tap into the turn signal wires because of their proximity of where I'm mounting the gauge.
The turn signal/running lamp circuit(s) are not the best circuit to use to monitor vehicle voltage, unless you enjoy watching the voltage rise and fall as the signal lamp flashes, and the running lamp goes out.
There are 2 clips, one white and one blue. Which is for the running lights?
The color of the connectors is probably okay to identify a circuit, however the color of the individual conductors, is a better method to identify electric circuits. See the available
wiring schematic here on ST-Owners.
And if I tap into the 2 wires feeding the clip it should work, right? I'm assuming 1 is pos and the other neg.
Oh No. Surely you know what they say about assuming....! Go to the wiring schematic that you downloaded from the link above, trace those conductors, and you'll see why this is wrong.
That's like the one I have, good choice!
The voltage meter would probably be of most use when it is connected as directly as possible to the battery, as the battery/alternator combo is the voltage source. Tapping into any other circuit, will influence the accuracy of the voltage reading, due to many factors; voltage drop over length of conductor, resistance at connectors, resistance of switches, resistance of relay contacts, resistance of the circuit back to ground.... The list goes on & on.
