Help ! Help ! The knob that operates the headlight does work , rotates ,clicks but the lights do not move up and down . Any body have any ideas ?? cheap fix or expensive ? thanks for any help.
Jeff, it is possible to remove and replace it without removing any plastic or headlight (search the article section and or threads to find it)Just replaced mine, $53 and you have to remove the plastic and headlight to install.
That would have saved some timeJeff, it is possible to remove and replace it without removing any plastic or headlight (search the article section and or threads to find it)
You can simply unscrew it and pull it backwards, then insert the new one, then carefully screw it back in.
Its about a 15 minute job.
I'm assuming Igofar is double jointed with 8 inch long fingers.....sheesh, I can barely get my hand up there to change a bulb, and my hands aren't that big....Jeff, it is possible to remove and replace it without removing any plastic or headlight (search the article section and or threads to find it)
The article in questionJeff, it is possible to remove and replace it without removing any plastic or headlight (search the article section and or threads to find it)
... yup...Is this the correct part?
http://www.partzilla.com/parts/detail/honda/HP-33130-MCA-003.html
Sent from my SM-N920V using Tapatalk
