Lewis pin tool kit
albany ny
ST1100
Welp...I was trying to add a little grounding to my 28 amp alternator and I managed to crack the alternator casting. I guess it's time for a 40 amp upgrade. Parts are on the way from partzilla. Does anyone have a Lewis pin tool kit I can use/rent or good instructions for making a Lewis pin?
thanks!
British Columbia
2021 RE Meteor 350
thanks!
Make one using the smooth shank end of one of the 28 amp alternator mounting bolts. You have three to play with. Drill a hole through one end of the pin to attach the extracting wire to. Getting the pin absolutely smooth on the cut ends makes pulling it out easier.
