Helibars exchange
Santa Maria
2002 ST1100
Hi all,
Has anyone changed their stock bars to "Helibars"? After a short ride, l will have a pain in my lower back from not being able to sit more up right. A search came up with these bars and they look just right, but at $500.00 I want to find more about them. Any problems you have run in to. I read that you can no longer lock your handlebars to keep
someone from taking it. So any help would be great.
Thanks Lee.
Dave.David
Rider
SB California USA
05,ST1300-04VTX1800R
8938
Hi all,
Thanks Lee.
I like the riser option. I added two risers, 2.5 inches, without having to change wires or clutch/brake lines. I did rerun throttle cables a different way, same way as if adding the Helibars. Helped me straighten out my back.
Dave.David
Rider
SB California USA
8938
Shot, I just noticed you are working with the 1100 and I did this work to my 1300 so I can't say if it would work the same.
Grand Junction, Colo.
92 ST1100
I had the earlier style of Heli-Bars on my 92 ST. They were fully adjustable at each direction change and allowed infinite positioning. Originally, I had 3" risers with original bars prior to Heli-Bars. The new model of those bars just doesn't allow for the adjustment locations. Which yr./model are you speaking of, as your sig. not showing that?
British Columbia
2021 RE Meteor 350
Sorry for the lack of info. I have a 2002 ST 1100.
Look for a used set of the original 1100 HeliBars, or try 2" Rox risers. Both have worked well for me. No problem with locking the bars though (???) as both options still allow full lock to lock steering and only some re-routing of cables/hoses required, without even detaching any of them.
West Michigan
'98 ST1100
8470
I also needed a set of risers to get a more comfortable riding position, so I made a set of home-brew risers for my bike. This meant I needed longer brake & clutch lines , but since the bike still had the original lines, I was due for a new set. I had Brake Material and Parts in Ft. Wayne, Indiana make a new set identical to the OEM set, but 4 inches longer. And I had to lengthen both of the handlebar switch cables.
Versailles, KY
2018 GL1800 Airbag
8693
I have the latest Helibars on my ST1100, and I didn't have to lengthen anything except install the brake line extension that was provided.
Looks like the ST1100 Helibars are being discontinued, but they have come out with a new bar for the 1300 that is very similar to the latest Helibar for the 1100.
Northbrook, IL
Hi all,
Thanks Lee.
I put the Helibar risers with Powerlet and Ram mount on my ST1300P. Worked great with no cable change, but it is possible that the Police model, which already comes with a short riser, had longer cables. Someone else may know. I love the position, which is just a bit forward, and the accessories are great. GPS on the Ram mount, tank bag with pass through SAE plug installed in front and accessories plus on the inside for phone power and misc. Hard to access under tank, which hits handlebars when lifted. This is aggravated by the longer Police switch pod right side.
