Rear wheel bearing identification number advice please.
Durham UK
Hi, I've just had my bike ( 2003 ST 1300 ) in for new tyres to be fitted and it was discovered that the wheel bearings in the rear wheel are badly worn.
I have done some searching on this excellent forum and think that I have the correct information but would just like confirmation please.
It would appear that the rear wheel has 3 wheel bearings fitted ?
Am I correct that I need to order 2 x 6905RS Bearings and that they sit back to back and then for the other side 1 x 6204UU.
Based on this info I contacted a local bearing retailer and the prices are great ie £4.50 each for the 6905's and £5.50 for the 6204.
He did mention though that this seemed a very odd setup as the 6204 and 6905 have different centre bore diameters?????
Any help or advice would be greatly appreciated.
Thanks Darryl
A steel collar press fits inside the 6905 bearings which reside inside the driven hub so those two 6905s have a larger ID inside diameter than the larger OD wheel bearings that slip over the axle. IIRC that is why.
Durham UK
Thanks that makes perfect sense.
In addition I think there is also a 20 x 47 x 20.6 or 5204 bearing so that will actually make 4 that I require
Yes, two wheel bearings and two driven spline bearings. Former support the weight of bike onto the axle and two align and support the spline hub.
Vancouver, WA
2007 GL1800
8714
I believe that there are four required bearings:
1) BEARING, RADIAL BALL (6905RS) --- 91052-KZ4-J2 (2 required)
2) BEARING, RADIAL BALL (6204UU) --- 91052-MAE-004 (1 required)
3) BEARING, RADIAL BALL (20X47X20.6) (NTN) --- 91053-MN5-003 (1 required)
Durham UK
Thanks so much.
That line drawing is a godsend and much appreciated.
My local bearing shop has all of those in stock so I will get them ordered.
Cheers Darryl
